Where is temperature sensor located?
Where can I find the temperature sensor on my 2003 Mazda Tribute 4 cylinder engine
Es esta una buena pregunta?
@chasp you did not tell us exactly what temperature sensor you are looking for. It might also help if you tell us why. The CTS (coolant temperature sensor) is screwed into the thermostat housing near the top radiator hose.
Fue útil esta respuesta?
Yes it's the coolant temperature sensor
under the intake manifold on the back of the alternator, better to remove the alternator so u can see the coolant temprature sensor.✌
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 80
Todo El Tiempo: 7,409
3 comentarios
Where is the heat sensor located on Mazda tribute 2003-2007?
- de Lavianna Stoops
where is the location of thermostat switch sensor of mazda tribute 2001 and to remove
- de Ferdinand Quijon
Where is the heat sensor located?
