Saltar al contenido principal
Guías de reparación y soporte para vehículos fabricados por la división Oldsmobile de General Motors (GM).
Preguntas 41 Ver todo
replaced broken blower motor resistor block works worse now
2001 Oldsmobile Alero - my blower fan was only working on the highest 2 settings I replaced the resistor block and now it's only working on the highest setting does anyone know why this might have happened or what could b wrong?
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
Solución Elegida
When the resistor goes its usually on the high settings if more than one works its usually the switch on the control that needs replacing . If it was the resistor and it went as soon as you installed it you need to replace the motor. Hope this helps
Fue útil esta respuesta?
Puntuación 2
pizon if the replacement of the resistor made it worse, double check your work and, if everything checks out, replace it once more.
Puntuación 0
Añadir tu respuesta
pizon estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 10
Todo El Tiempo: 202
