Saltar al contenido principal
Cámara SLR de enfoque manual de 35 mm fácil de usar. Número de modelo X-370.
Preguntas 26 Ver todo
Why am I seeing black after I take a picture?
When I go to take a picture I hear the shutter sound but all I see is black. I open up the film door and check there is a thin black sheet right behind the film that is not closing all the way. I have put new batteries in.
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
Your shutter is stuck. This has the side effect that the mirror will not return to its normal position, which blacks out the viewfinder.
Problems like these are not unusual in older cameras, and should be looked at by someone who's familiar with these old mechanical beasts. Avoid messing with the camera as you might make things worse - shutters are very delicate mechanisms. Keep in mind that spare parts are no longer readily available for these cameras.
EDIT:
Some research tells me that stuck shutters are a common problem with this particular camera.
There appear to be different causes for this problem. Sometimes, it appears to be a matter of "lack of exercise". One suggested solution is a gentle whack against the palm of the hand :) , another is the use of a fingernail to gently persuade the shutter to close completely - but be careful! In other cases, the problem seems to be caused by the camera's electrics, specifically, corrosion due to old leaking batteries. Check the inside of the battery compartment for corrosion, if you find any (greenish crud) have the camera cleaned and inspected - the corrosion may have propagated outside the battery compartment.
Fue útil esta respuesta?
Puntuación 2
Añadir tu respuesta
Marissa martinez estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 33
Ultimos 30 días: 112
Todo El Tiempo: 4,765
