How to change fuel filter 2007 jeep wrangler
Where is the fuel filter on my 2007 jeep wrangler JK and how to replace it?
Es esta una buena pregunta?
fxdwg96pete, on your model there are two fuel filters being used. One at the bottom of the fuel pump module and the other inside the module. This Jeep does not use the older type that were mounted to the frame etc. It is also not necessary to replace the filters as part of a routine maintenance. You only change these in case of an engine diagnostics. i.e. OBD code. A separate frame mounted fuel filter is not used.
Fue útil esta respuesta?
Ultimas 24 horas: 8
Ultimos 7 días: 30
Ultimos 30 días: 124
Todo El Tiempo: 24,700
2 comentarios
We’re is in line fuel on a 07 Rubicon
- de Darrell Mullins
How to determine her a bad Throttle body
