Saltar al contenido principal
-EF Lente de montaje -Rango de apertura: f/3.5-36 -Estabilización óptica de imagen -Motor de enfoque automático ultrasónico -Sistema de enfoque interno -Manual de anulación de enfoque Distancia de enfoque mínima constante: 20" -72mm Diámetro de la rosca del filtro
Preguntas 3 Ver todo
Canon 28-135 f/4.0 IS USM Lens resist on turning
Hey guys
i totally no idea why does my lens resist on twisting whenever i zoom in or zoom out, i does require a certain amount of force just to twist the barrel of the lens.
how to fix this?
Es esta una buena pregunta?
Puntuación 4
1 comentario
I have the same problem and it has gotten worse to the point that the lens is almost unusable
- de
Agregar un comentario
4 Respuestas
Solución Elegida
Hello Jan!
if the barrel is broken, you will need to replace it and additionally buy the CANON EF 28-135MM F 3.5-5.6 IS BASE ZOOMING GUIDE by $6 USD
http://www.procamerarepair.com/search.as...
i EXPECT can be usefully my answer.
good luck!
Fue útil esta respuesta?
Puntuación 3
The same thing happened to my lens and I tried to zoom in and zoom out forcefully and suddenly it snapped and a ring broke in my lens so don't try to apply force. I watched this video on YouTube to fix my lens but I seriously advise you to get it fixed if you don't want to try to fix it by yourself still I am copying the link to the video. Hope this helps.
https://youtu.be/PMUXqfTEXsA
Puntuación 2
my lens is stuck at 135, i mean it believes that is at 135 even though i am at 28, anyone knows something about that?
Puntuación 2
It could be that the lens threads are out of position with a slightly bent lens.
This has helped me getting it fixed, maybe that also helps others
https://www.youtube.com/watch?v=_4K1Ge5C...
Puntuación 2
Añadir tu respuesta
Jan Buencamino estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 6
Ultimos 30 días: 39
Todo El Tiempo: 4,144
