First Generation Toyota Tacoma Tire and Wheel Fitment
Aftermarket Wheel Fit Reference Guide. [Original Source|http://web.archive.org/web/20081007213703/http://www.ttora.com/wiki/index.php/Tire_and_Wheel_Fitment]
15" Wheels that FIT
- Allied "Daytona" black steelies, 15x8/3.75bs, 2001 TRD w/o ABS (no cab,drive,or engine given).
- Allied "Daytona" black steelies, 15x8/3.75bs, '97 Tacoma (no cab,drive,or engine given)
- American Eagle 1189, 15x8/3.75bs, 2002 Tacoma 4WD V6 DC.
- American Racing Baja, 15x8/3.75BS, 2004 Tacoma 4WD V6 XC.
- American Racing Baja, 15x10/3.75 BS "fit my 04 w/ABS" (no cab,drive,or engine given)
- American Racing Baja, 15x10/3.75bs, 1997 Tacoma 4WD 2.7L XC.
- American Racing Daytona 84 series, 16x7/4 BS, 2001 Tacoma 4WD V6 XC.
- American Racing Diamond Lock I, 15x8, 2003 Tacoma 4WD V6 XC.
- American Racing Diamond Lock II, 15x8, 2004 Tacoma 4WD V6 XC.
- American Racing Type 23 (AR23), 15x8, 2002 Tacoma (no cab,drive,or engine given).
- Cragar, 15x7/3.75BS, 02 SR5 TRD with ABS. (no wheel model given)
- Eagle 186/187, 15x10/3.625bs, 2004 Tacoma 4WD DC.
- Eagle 187, 15x8/3.25bs, 2004 Tacoma 4WD DC.
- Eagle 589(058), 15x8/3.25bs, 2002 Tacoma.(no cab,drive, or engine given)
- Eagle 639(063), 15x8/3.25bs, 1999 Tacoma 4WD V6 XC.
- Mickey Thompson Classic Lock 468412, 16x8/4bs, "2001-2003 prerunners...or 4wd w ABS".
- Mickey Thompson Classic II, 15x8/3.3125bs, 2001 Tacoma 2WD V6 DC.
- Mickey Thompson Classic II, 15x8/3.3125bs, 2003 Tacoma PRE V6 DC.
- Mickey Thompson Classic II, 15x10/3.625bs, 2004 Tacoma 4WD V6 XC.
- Mickey Thompson Classic II, 15x12/3.625bs, 2004 Tacoma 4WD V6 XC.
- ProComp Rock Crawler 87-5883, 15x8/3.75bs, 2001 Tacoma 4WD V6 DC.
- ProComp Xtreme 1079, 15x8/3.75bs, 1999 Tacoma PRE V6.
- ProComp 8179, 16x8/4bs, 2001 Tacoma 4WD V6 XC.
- Ultra type 50, 15x8, 3.75bs, 1995 Tacoma 4WD I4 XC.
- Ultra type 164, 15x8,...these do fit up to 04 tacomas
- Unique 72313, 15x8, -19mm offset(3.75bs), 2002 Tacoma 4WD V6 XC.
- US Wheel 97 series, 15x8, 2002 Tacoma 4WD V6 XC.
- Wheeler's BLACK Toyota Steel Wheel, 15x8: TYPE A (no truck year given)
- Wheelers 15x8 Black and Chrome, Type "A" and "B" (They all fit (2000-2004 4WD and Prerunner); they are engineered to fit without modifications) Provided by Nilson. Wheelers website says they will fit 95-04 without VSC.
- Weld wheels, 15x10 fit on my 2004 double cab. (no wheel model given)
- Weld Cheyenne, 15x10/4.5bs, 2002 Tacoma 4WD XC. (MUST USE 1/4" SPACER)
- Weld Outback, 15x8/?.?bs, 2002 Tacoma 4WD V6 DC.
15" Wheels that DO NOT FIT
-97 series (no truck year given)
-97-5883, any Tacomas without grinding, to my knowledge.
-Alcoa 15x10's, (will fit w/spacers)(no truck year given)
-Allied "Daytona" black steelies, 15x8/3.75bs, 2004 (with ABS)(no cab,drive,or engine given).
-American Racing Black Daytona, 15x8, 2001 Tacoma (no cab,drive, or engine given)
-Cragar Steel 3975860, 15x8/4 bs., 1997 Tacoma 4WD V6 RC. (Will fit with 1/4" spacer)
-Rockcrawler 97-5883, 15x8/3.75bs., 1999 Tacoma 4WD V6 XC.
-Rockcrawler Series 51. Please see comments below in "OTHER COMMENTS" for these.
-Unique (I believe this is the brand) black steel wheels, 15x8, 2001 Tacoma(no cab,drive, or engine given)
-US wheels 84 15x8/3.75bs. Please see comments below in "OTHER COMMENTS" for these.
-Weld Cheyenne, 15x10/4.5bs, 2002 Tacoma 4WD XC. (Will fit with 1/4" spacer)
16" Wheels that FIT
-Eagle 186, 16x8/4bs, 1999 Tacoma 4WD XC 2.7
-MB Motoring Blitz, 16x8, 2001 Tacoma 4WD XC.
-MB Razor, 16x8, 2004 Tacoma 4WD Single Cab, 2.7
-MB Motoring Rocker, 16x8 4.25"bs, 2002 Tacoma dbl cab
-Unique 42 16x7 0 offset (about 4" bs), 2003 tacoma with ABS (sold at discount tire)
16" Wheels that DO NOT FIT
-Rockcrawler Series 51,16x8/4.25bs, 2002 Prerunner. Will fit w/.25 spacer. Also see comments below.
OTHER COMMENTS: For what they're worth...
-US wheels 84's, 2004 Tacoma (no cab,drive,or engine given). had to grind the drivers side caliper down a 1/8" and about twice as much on the passenger side. go figure
-US Wheel series 84, 15x8" 3,75" backspacing, 2002 Tacoma 4WD V6. here's the weird part....one wheel rubbed driver's side only, one wheel rubbed passenger side only, one wheel rubbed both sides, two wheels did not rub at all...4 were bought together brand new from Summitracing.com....one of the wheels that didn't rub was bought from a TTORA member...but it was still new and also from Summit.....
-US wheels 84, 15x8/3.75bs didn't fit, 2004 Tacoma (no cab,drive,or engine given)
-US Wheels 84-5860L (15x8 3.75" BS) do not fit, they need about an 1/8" off the calipers. Probably not even that actually, I snugged them on and I could still spin the wheel but it rubbed. 2004 Tacoma 4WD V6 DC.
-US Wheels 84 Series, 15x8/3.75" BS fit, 2000 4WD V6 XC Tacoma. They are very close to the caliper but did not require any grinding or modification. Purchased in 2002 - Heard the manufacturing of these may have changed since then.
-I used (1/4") spacers on mine to make it fit. They look good! (2000 tacoma, 15x10 Crager Black Steels, 4" bs
-In 2003 and on, ABS was standard on EVERY tacoma. Funny. Pain to find before that. And now standard.
-so the Rockcrawler Series 51 at 4wheelparts do not fit? nope, it hits the caliper. i tried it, both 15 and 16" (2002 Tacoma) (no cab,drive,or engine given)
Tacoma Caliper Info
RC=Regular Cab
XC=Extra Cab
DC=Double Cab
PRE=Prerunner
SRU=Srunner
VSC=Vehicle Stability Control
These Tacoma's use the same calipers: LIST A
95-04 2WD I4(2RZFE) RC
95-04 2WD I4(2RZFE) XC
95-04 2WD V6 XC
These Tacoma's use the same calipers: LIST B
99-04 2WD I4(3RZFE) RC
98-04 PRE I4(3RZFE) XC
01-04 PRE I4(3RZFE) DC
03-04 SRU V6 XC w/o VSC
98-04 PRE V6 XC w/o VSC
01-04 PRE V6 DC w/o VSC
95-04 4WD I4(3RZFE) RC
95-97 4WD V6 RC
95-04 4WD V6 XC
01-04 4WD V6 DC
These Tacoma's use the same calipers: LIST C
03-04 SRU V6 XC w/VSC
98-04 PRE V6 XC w/VSC
01-04 PRE V6 DC w/VSC
This one uses a different one than all the rest: LIST D
95-04 4WD I4(3RZFE) XC
It seems to me that the VSC calipers are the only four piston calipers. As far as I can tell looking at the puny pictures. Edited: VSC calipers are NOT the only four piston calipers. I know for a fact that LIST B is a four piston caliper. Others may be as well.
Added: According to Wheelers Offroad, if you have VSC no 15" wheel will fit. You must stay with at least a 16" wheel. Added: I've read comments about the hub center changing size for 2003+. Toyota's part number for the axle hub is the same for 2000 through 2004. The investigation continues...
This information probably gives us a reason as to why some 15" wheels fit some Taco's and not others.
ricomann- I have a 95.5 SR5 taco ex-cab, my truck has four piston calipers on it from the factory.
2 comentarios
Also, you can fit the 2010 Toyota Hilux 16'' rims. I use it as my replacement tire rim as I got stolen the original one.
masodi.aarash - Contestar
Will vision 85 soft 8 15x7 -6mm fit on my 97 4wd v6 ext cab?
Jon V. - Contestar
