Wiki con Contribuciónes de Estudiantes
Esta wiki ha sido creada por un increíble grupo de estudiantes de nuestro programa educativo.
Screen Backlight is Always on
The tablet's screen light is always on, even when the device is in 'sleep' mode.
Update your firmware.
Make sure that your tablet's software is up to date with the latest firmware. Install the latest Windows 10 update.
Restart Tablet
Turn off the Tablet and turn it back on to see if it is just a process error.
Battery will not charge or the battery is drained even after charging
The tablet will not charge or hold a charge.
Ensure that you are using a proper charger.
Charging a tablet required a higher wattage. Ensure you are using the right charging port to efficiently charge the tablet.
Replace the Battery
Purchase a new battery to install in the tablet.
Audio is distorted due to a broken or obstructed speaker/ headphone jack
The tablet will not play sounds or play sounds through the headphone jack.
Restart Tablet
This is a good starting point. Sometimes, there will be an error that prevents the audio from playing. Restart the tablet and then try playing again.
Clean out speakers and jacks
Make sure that the speakers and headphone jacks are clear of debris. Lint and dust is often found in these areas.
Screen is frozen or unresponsive
The tablet's screen is displaying the same screen or not responding to commands.
Restart Tablet
Do a hard restart of the device to end all tasks and start from a clear process again.
Front-facing or rear-facing camera is broken
The tablet's camera is either broken or unresponsive.
Try Cleaning off Camera
Make sure there is nothing obstructing the camera's point of view.
Check camera connections
See is the camera is still properly connected to the motherboard.
Replace Cameras if Cracked.
The camera is glass so, if cracked, replace and restart the device.
0 comentarios
