Wiki con Contribuciónes de Estudiantes
Esta wiki ha sido creada por un increíble grupo de estudiantes de nuestro programa educativo.
Camera won't turn on
No matter what you do, the camera will not turn on.
Camera is new
When you've just taken your camera out of the package it will likely have no charge. This can be resolved by charging the battery in two ways. First, plug the battery into the charger. Another options is to plug the camera, with the battery in place, into a USB port.
Power button not held down
Before diving too far into the inside of your camera, be sure that you press and hold the power button for at least 5 seconds. Sometimes it takes a while for the camera to fully power on.
Drained/Dead Battery
If your camera won't turn on, especially if it has not been used recently, you may simply have a drained battery. Charge your battery by first removing it from the camera and then load it into the battery charger. Ideally, if it's a drained battery, the camera should turn on after charging the battery for a few minutes. If the camera still fails to turn on, then a replacement battery must be used. See the battery replacement guide for assistance.
LCD screen will not function/display
The screen is blank or appears dark.
Camera is off
If the LCD appears black, make sure that the camera is turned on by holding the on/off button. Be sure that the power light is on. In addition, make sure the battery is fully charged and is inserted properly.
Front cover position
If the LCD appears black and the camera is turned on, make sure that the sliding front cover is at the down position so the lens is displayed.
Backlight is off
If the LCD appears black while the camera is turned on and the front sliding cover is down, the LCD backlight may be off. To turn the backlight on, press the "display" button several times.
Reset to factory settings
If the previous steps have all been performed and the LCD still remains black, the camera may need to be reset to factory settings.
Bad display
It is possible that nothing appears because the display is bad. The display may need to be replaced. See the screen replacement guide for assistance.
0 comentarios
