Wiki con Contribuciónes de Estudiantes
Esta wiki ha sido creada por un increíble grupo de estudiantes de nuestro programa educativo.
Shark Rocket Complete (HV381) Troubleshooting
The Shark Rocket Complete (HV381) is a vacuum cleaner that was released by Shark in 2016.
Vacuum will not stand up
The vacuum will no longer stand up on it own
The Complete could never stand
The Shark Rocket Complete, or the Complete for the sake of brevity, lacks two things that can be found in the previous series: a HEPA filter and the ability to stand on its own. A common misconception that many new users have with their Complete is that the latch is broken. In reality, the Complete was designed to be stored in a closet or propped against a wall when not in use.
Vacuum will not pick up particles
The vacuum has lost a considerable amount of suction or has none at all
Dust cup is full
Before continuing to any other step, empty the dust cup to ensure that is not the problem. When full, the Complete should turn off automatically to alert the user that it is full, but if it is not entirely full, suction can still decrease.
There is a blockage in the vacuum cleaner
Look for any thing blocking the hose and the attachments. Clean the blockages out of the attachments by shaking them until the debris falls out. As for the hose, remove, run water through, and allow the hose to dry for 24 hours.
The dust cup is too dirty
In some cases, the Complete will lose a considerable amount of suction even after emptying the dust cup. This is due to dust cup being too dirty. Simply get a moist, warm rag and clean up all visible dust. For tough to clean stains, it is best to let the cup soak in warm water for 15-20 minutes and to attempt to clean it again. Remember to properly dry the dust cup before putting it back in its proper place.
The filter is too dirty
Start by opening the pre-motor filter lid. This is the lid that is located just above the dust cup. Remove the two white pads that are found inside. Remove the post-motor lid located underneath motor and remove the two white pads that you see in there also. It is important that you rinse under water only. Do not use soap. Let the filters air dry for at least 24 hours. The pre-motor filter should be cleaned monthly and the post-motor filters every year.
Vacuum turns off on its own
The vacuum keeps randomly stopping or not turning on
Vacuum is not properly plugged up
Check to see if the plug is loose or if you are going too far for the Complete. If the plug is loose, then try switching to a different outlet or using an extension cord. If still loose then contact customer service at 0-800-862-0453.
The motor has overheated
Reset the thermostat by following the instructions below:
1. Turn the Complete off.
2. Unplug the Complete.
3. Empty the dust cup and clean the filters.
4. Check for blockages.
5. Let the Complete cool for thirty minutes.
6. Plug the Complete back into the outlet.
7. Restart the Complete by turning it on.
A faulty battery
Please see our comprehensive guide for the replacement of the Complete battery.
Vacuum smells like it is burning
The vacuum creates either a burning smell or fire
The dust cup has flammable material inside of it
One of the most probable causes is that the vacuum picked up something that contained embers such as a lit cigarette. If this is the case unplug the vacuum cleaner and empty the dust cup.
The motor is dysfunctional
For a comprehensive guide to removing/replacing your motor, you should view our guide here.
The drive belt is dysfunctional
You can also check here for a guide for removing/replacing your drive belt.
Duo Clean is no longer picking up particles
Vacuum is partially picking up, but the attachments pick up fine
An unclean vaucum head
1.) Unplug the vacuum cleaner.
2.) Check here for the removal/attachment of the vacuum head.
3.) Lay the vacuum head on a piece of newspaper/paper so that all the debris can be picked up later.
4.) Use one end of a scissor to cut away any hair and pull the rest of the debris off by hand.
5.) Wipe the roller with a damp rag and throw away all the remaining trash.
5 comentarios
Not sure where to find the info for a motor not working…. Where is a link to that guide?
Colton - Contestar
Need a new short hose that is in motor compartment.
Frank - Contestar
Buy one at Amazon. Lower replacement hose for- Shark and model number.
Curt mueller -
The manual says there is a suction release on the handle/???? though doesnt show its location not can i find it....anyone?
dianedebaun - Contestar
It’s there! It slides left and right or up and down.
Curt mueller - Contestar
