Samsung Galaxy Tab 3 7.0 Troubleshooting
Something about your Galaxy Tab needs fixing? Look no farther!
Tablet Doesn't Turn On
No matter what you do, you can't get your tablet to turn on.
Press and Hold the Wake/Sleep Button
If this does not resolve your problem, read on!
Check If Battery Will Charge
First, connect your tablet to the power adapter. Hopefully the tablet will recognize the charger and begin to recharge the battery. If it does not, the battery may be defective and need to be replaced.
Faulty Display
If you determined that the battery was working, it is possible that the display is broken. If no light or images are visible, but the tablet has power, then the display may need to be replaced.
Bad Logic Board
If none of the previous solutions solved your problem, check all of the connections from the display to the logic board. If the device still does not turn on, the logic board in your device most likely needs to be replaced.
Screen Doesn't Respond to Touch
Nothing happens when I touch my screen.
Screen protector/tablet case interferes with the touchscreen
Try removing your screen protector or case from the device, and test the touchscreen again.
Caution: Some screen protectors may not reapply properly.
Perform a Soft Reset
A soft reset restarts your device and does not erase any of your content or data. Begin by pressing and holding the Power key until your device turns off. Wait a moment, then press and hold the Power key to turn your device back on.
Bad Touch Screen
The touch screen may be bad and need replacement. The front panel (which includes the touchscreen and digitizer) should be replaced.
Bad Logic Board
If the problem persists, the logic board may need to be replaced.
Tablet Overheats
Tablet is too hot to touch!
Reset the Device
Hold down the power button until the device shuts off. Let it cool down for a few minutes, then hold the power button until the device powers on.
Bad Battery
If the device continues to heat up, the battery is most likely defective and needs replacement. Purchase a replacement battery, and replace the old with the new.
Tablet Performs Slowly
Safely Remove Your SD Card
From the home screen, tap the Menu key, then tap Settings. Once in Settings, scroll to and tap Storage. In Storage, scroll to and tap Unmount SD card, then tap OK. You can now safely remove the SD card.
Close or Uninstall Applications
In the Power Usage dashboard, tap Battery Usage. Next, tap the application you want to close or uninstall.
- To close (turn off) an application, tap Force stop.
- To uninstall (remove from device) an application, tap App info, Uninstall, and then OK.
Verify That Your Tablet is Running the Most Recent Software
Begin by tapping the System Updates dashboard. Next, tap Device Software, then tap Check now. If an update is available, follow the prompts to install.
Tablet Doesn't Produce Sound
No audio from headphones, speakers, or tablet itself.
Bad Headphones/Speakers
Check to make sure your playback method isn't the problem. Check all speaker connections and test headphones on another functioning device. If the problem is not resolved, your tablet may be the issue.
Software
First try a full restore on the tablet to make sure it is not an issue with the software.
Bad Audio Jack
If the problem is still not resolved, try replacing the audio jack. If that doesn't solve the problem, your logic board most likely needs replacement.
55 comentarios
My screen is cracked & the display has lines It can't be used. Is it just the digitizer or something else?
shelldogs - Contestar
When you say the display has lines. Do you mean that if you try to look at a picture a whole line is of dead pixels?
Mohammad W Jee -
Shelbie girl is that you chica?
April Whitt -
Anytime I do anything on my tablet from going to settings, google play, or even the touch wiz home a message pops up say unfortunately the process has stopped working. I did a factory reset and it still does it. Any suggestions?
kathy - Contestar
Its a samsung tablet 3 7.0
kathy -
