Wiki con Contribuciónes de Estudiantes
Esta wiki ha sido creada por un increíble grupo de estudiantes de nuestro programa educativo.
Vacuum Will Not Turn On
I want to use my vacuum but it won’t turn on when I press the power button or it shuts off mid-use.
Vacuum Not Plugged In
Check to make sure you have attached the power cord of the vacuum to a wall plug.
Overheated Motor
If the vacuum cleaner stops working mid-use, this is because the vacuum motor has become overheated and the machine shut itself off as a safety procedure. If this occurs, let the vacuum rest for 1-3 hours, then come back and turn it on again for use.
Bad Wall Socket In Your House
A wall plug in your house might not be working. Try plugging the vacuum into a different wall plug.
Faulty Vacuum Cable
Wiggling the vacuum power cable may cause power to come back on. But this does imply that it is a bad power cable. Contacting the vacuum company is necessary if this happens.
Low Suction/ No Suction
When I turn the vacuum on it won’t pick up dirt or debris.
Dirt Cup Clogged Or Full
Try emptying the dirt cup into a waste receptacle.
Clogged Hose
Check hose and brush roll for obstructions.
Use a long object such as dowel or ruler to push debris through suction hose.
Dirty Filter
Rinsable filter or HEPA filter is dirty, clean the filter with water or replace HEPA filter.
*NOTE: DO NOT WASH FILTER MADE WITH HEPA MATERIAL!
Link to replace filter guide
Automatic Brush Roll Shut-off Engaged
Press automatic brush roll shut-off switch twice.
Broken Or Damaged Belt
Belt connecting brush roll to vacuum is damaged or broken.
Link to replacement belt guide
Part: Hoover Belt Part #562535001
Tools Required: Phillips head screwdriver
Body And Handle Won’t Recline
The cleaner is stuck at just one position or the handle would not recline as much as it used to.
Vacuum Head not Pressed Down
Make sure the vacuum head is held fixed on the ground using your feet while pulling the handle to adjust its position.
Object Stuck At The Hinge
Look for any blockage around the hinge that connects the cleaner head and the vacuum handle. An object such as pencil stuck at the hinge might be preventing the unit from reclining further.
Faulty Upright Lock
Look for any blockage around the hinge that connects the cleaner head and the vacuum handle. A pencil stuck at the hinge might be preventing the unit from reclining further. Check if something is stuck by the upright lock. If it is broken, the part will have to be replaced.
Part: Hoover Lock #440004075
Tools Required: Allen Wrench Screwdriver
Making Loud Noise
The vacuum makes a strange or loud noise whenever it is turned on.
Clogged Hose
If the vacuum is making a whistling noise, the hose of the vacuum may be clogged with dirt or debris. Use a moist paper towel and/or a long object such as a dowel or a ruler to clean away any obstructions.
Part: Hose
Tools Required: Moist paper towel, long object
If unclogging the hose does not resolve the issue, the hose itself may be torn or ripped and replacement may be required.
Clogged Motor Filter
There may be a buildup of debris in the motor filter. This can be accessed by unscrewing the back panel on the bottom of the vacuum. Once panel is removed, pull out the motor filter and wash with water.
*Warning: Allow filter to completely dry before reinserting into compartment!
Part: Motor Filter
Tools Required: Phillips head screwdriver, Water
Solid Debris Inside Dirt Cup
If the vacuum is making a rattling noise, you may have simply sucked up a solid piece of debris such as a small stone. Remove the dirt cup and empty contents into a waste receptacle.
Part: Dirt Cup
Tools Required: None
Brush Roll Will Not Spin
When operating the vacuum, the primary brush roll is not spinning.
The Brush Roll Switch Is Turned To “Off”
Make sure the switch is pushed into the “on” position. If it is in the on position, switch to off and then back to on.
The Brush Roll Is Clogged
Physically inspect the brush roll for debris that may be clogging it and preventing it from spinning like hair or string. Remove the material.
The Brush Roll Doesn’t Work
The brush roll may no longer be functional. If the above steps don’t resolve the problem try unplugging the unit for 30 minutes and then try again. If the problem is still unresolved you probably need to Replace the Brush roll (link to replacement guide for brush roll).
Dust Escapes Vacuum
When using the vacuum dust is escaping and getting blown out.
Dirt Cup Is Full
Dust may escape if the dirt cup is full. Empty the dirt cup and see if the issue persists.
Parts: None
Tools required: None, gloves recommended
Dirt Cup Not Installed Correctly
If the dirt cup is not properly seated dust may escape. Ensure the dirt cup is properly installed by removing the cup and then placing the bottom on the dirt cup into the body of the vacuum first, then pivot the cup into the vacuum. You should hear and feel a click. If the dirt cup doesn’t fit or click into place you may need to buy a replacement dirt cup.
Parts: Hoover Dirt Cup- part no. 440004067 (if required)
Filter Missing Or Not Properly Installed
If the filter is not installed properly, or is missing altogether, then dust may escape while the vacuum is in use. See our Filter Replacement Guide for instructions on how access and check the filter. You may need to replace the filter if it is old or damaged.
Part: Primary Filter Assembly- part no. 303903001 (if required)
54 comentarios
any chance you’d be open to helping troubleshoot an issue not mentioned here? my hoover windtunnel air steerable upright is having issues with the air flow. when i open ‘hose mode’ valve the air spins in the dirt cup as it’s supposed to, but when i close that and use the standard floor mode the air stops spinning and sounds as though there’s nowhere for air to escape. i’ve cleaned out all the hoses and pulled apart the vacuum as much as i can, but i just can seem to see an issue. any thoughts on what might be causing this issue? thanks! :)
Janaya Rampton - Contestar
I am having that exact problem! How do I fix it?
Megan Hall -
My issue with this vacuum is that the debris that is sucked up winds up on top of the air filter and not in the dirt cup where it’s suppose to be.
Chuck Kalb - Contestar
Chuck, I’m having the same issue with my Hoover Windtunnel, did you ever find a solution to fix the issue? If you can share your experience in fixing the problem, that would be awesome. Thanks.
Jose Blanco
Jose Blanco -
Same here. And I just replaced both filters to no avail!
Jessica McCauley -
