Wiki con Contribuciónes de Estudiantes
Esta wiki ha sido creada por un increíble grupo de estudiantes de nuestro programa educativo.
Camera won't turn on
Your camera will not boot after you press power button
Battery
If you hold the power button and the camera does not turn on, it could be due to a problem with your battery. It is either not charged, or it is permanently dead. If it is not charged, take out the battery, remove the cover and use only the provided charger to charge the camera. After waiting about four hours, take the battery off the charger and place it back into the camera. If this does not work, then you may have a bad battery.
Battery life drains too quickly
Your battery loses its charge quicker than normal
Temperature Problems
Battery performance decreases at low temperatures. Warm the battery, for example, by placing it in your pocket with the thermal cover on it.
Battery Drain from LCD
The LCD uses most of the battery power inside the camera. When taking photos or using viewfinder, turn off the LCD to conserve batter. To do this, press the menu button. Once in the menu, use the left and right buttons to get to the tools tab. Within the menu, use the up and down keys or the dial to locate LCD brightness. Here you can turn the brightness on the screen down, which will allow you to save more battery. Also, you can set a power saver mode, which will shut off the camera after a period of time where it is not being used. Again in the menu, locate the tools tab then the power saving option. Here, you can turn the power saving option on or off, as well as set the amount of time needed before entering power saving mode.
Lens Error Message
Upon turning on the camera, a message says "lens error, will shutdown automatically, restart camera"
Debris in Lens
It is possible that you are receiving this message due to a build up of debris or grit inside the lens. First, turn off your camera and remove the battery and SD card. Next, use compressed air to blow into the lens casing hoping to remove any possible debris. After cleaning the lens casing, replace the battery and SD inside the camera, and try to take pictures. If this does not eliminate the error message, you may need to replace your lens.
Lens is out of place
If the lens has been knocked out of its original position, your camera will display the lens error message. There are little grooves on the inside of the casing that the lens sits in, however if the camera sustains impact, the lens could get hit out of place. If your lens appears to be slightly out of place, first remove the battery and SD card. Lay the camera on a hard surface with the lens facing towards the ceiling. Very gently press the lens down with your thumbs until you hear a click. This means that you have gotten the lens back into its grooves. Insert the battery and SD card and try again. If this does not solve the lens error message, the lens must be replaced.
Camera Does Not respond to input
The function buttons on the camera do not interact with camera
Low Battery
This occasionally happens due to low battery. Even though the camera still turns on, it may become unresponsive. Replacing the battery should fix the problem.
Other problems
I cracked my display, but I think I can replace it
For directions on how to replace the display, follow this guide.
5 comentarios
when I turn the camera on I get the following message:
A camera error was detected
Will shut down automatically
Restart camera
E40
This message appears over and over but camera will not start up.
Help Please!!!!!!!!!
Harry - Contestar
i could not get camera to come on , charged battery and the zoom works and the flash goes off , but the display screen inside and out will not come on
paul shaw - Contestar
Camera fell. Later AF isnt working correctly. Even if I use Manual focus. It's not getting sharp after a point. Orginal image looks blurry in edges.. what wrong.
sai shankaran - Contestar
My data transfer cable will not connect to camera socket, cable is fine, connects to other appliances.
Has always connected to camera in the past. ???
Michael Belanger - Contestar
My camera display has a foggy border all around the image. When downloaded the actual image is fine. Does the display need to be fixed?
Fernanda - Contestar
