Wiki con Contribuciónes de Estudiantes
Esta wiki ha sido creada por un increíble grupo de estudiantes de nuestro programa educativo.
Drill Turns Slowly
You have trouble driving or loosening a screw
Discharged Battery
This is the most common issue with a lack of torque in the drill. Remember this is not an industrial grade drill and is ideal for smaller projects. (i.e. putting together a bookshelf)
Faulty Battery
One of the most common issues with cordless drills is battery life. If all other solutions have not worked it may be necessary to change your battery. Replace your battery [URL|using this guide.]
Drill Will Not Power On
Your drill is not powering on when pressing the trigger.
Discharged Battery
Ensure that your battery is fully charged. The battery life on this drill is not extremely long, and will decrease after many uses.
Faulty Trigger
The trigger in the drill may be faulty. Ensure that you have exhausted other less invasive options before replacing the trigger. Replace the [URL|trigger using this guide].
Forward/Reverse Selector in Neutral
Check to make sure that the safety is not engaged. If the switch is in the center position it will not operate.
Drill Turns in Incorrect Direction
Your drill turns the opposite direction that you want.
Forward/Reverse Selector Switch
This could be due to not having the selector switch in the correct position. Check the button directly above the trigger to make sure its in the correct position.
Drill Has No Torque
Your drill will not drive a screw, remember this is not a powerful drill. Try the steps below, if none of them work you may consider using a more powerful drill.
Torque Selector Ring
Your drill has different torque settings to prevent stripping or driving a screw to far into soft material. Try turning the ring behind your chuck to a higher setting.
Discharged Battery
If changing the torque settings does not work, check to make sure your battery is fully charged.
Faulty Battery
If your drill is sluggish and does not seem to be working for even the softest materials consider changing the battery. Replace [URL|using this guide.]
Drill Will Not Charge
Drill does not power on after charging for a long period of time.
Charger Cable
Check your charger cable to make sure that it is plugged in properly. If this does not work check to make sure the cable is not frayed or cut anywhere.
Faulty Battery
After exhausting the steps above you may have a bad battery. Replace[URL| using this guide].
Charging Port
Your charging port may be bad. If you have already replaced the battery and the drill still does not work your charging port may be bad. Replace[URL| using this guide.]
Charge Indicator Light
It is also possible that your battery is charging by your indicator light has gone bad. Check to see if your drill works, it is does but the indicator light is still not flashing or on you will need to replace it. Replace [http://|using this guide].
Chuck Will Not Open/Close
The drill will not open for a new bit, or close around the existing bit.
Chuck Completely Opened/Closed
The chuck may be jammed with dirt, you will most likely need to clean it. Do so and try again.
7 comentarios
What part of drill do I clean and also how do I clean it?
Ann Spangler - Contestar
Reply to Ann spangler
Ann Spangler -
My drill won’t charge. Light flickers but never goes steady. Drill turns a second or two & quits. How to know if it’s the lithium battery or charger? I’ve had it a few years but only used a handful of times. It is the LDX172C.
lcquaid - Contestar
works when battery first installed , but will not restart after setting a minute.
Norman Beckman - Contestar
I was working with it and it just stopped powering the motor even though the light comes on and looks bright. Nevertheless to be sure it was not discharged I put it on the charger until the light stopped blinking green. I did not drop it. If it is the switch malfunctioning how do I determine that?
James Hempler - Contestar
