Wiki con Contribuciónes de Estudiantes
Esta wiki ha sido creada por un increíble grupo de estudiantes de nuestro programa educativo.
Maximum Battery Life is Shortening
Longevity of battery is shortening, resulting in more frequent charging.
Overcharging
When any lithium ion battery (found in most devices) is continually charged without needing it, the battery will be damaged over time and eventually lose charge capacity.
Normal Wear and Tear
Over time the battery will lose its ability to hold charge as effectively as once before. Click Here for battery replacement guide.
Broken or Cracked Screen
Screen glass is broken/warped, but no signs of image distortion, discoloration, or absence of display.
Dropping Laptop and/or Blunt/Pinpoint Force to Screen
Physical damage to laptop can result in a cracked screen. If all screen functions of laptop are intact, screen glass may be replaced.
Heat Damage to Screen
Screen can be replaced if heat damage affects screen function.
Screen Will Not Turn On
Black Screen/No display.
Loose or Deteriorating Connection From Laptop to Display
Connections from laptop to display are stressed whenever the lid of the laptop is opened or closed. Over time wired connections may become worn and cause display to flicker or go black. Repairs should be done by a professional.
Screen Brightness Setting is too Low
Follow the instructions below to turn up/adjust your screen brightness.
- Hold Function (fn) button on lower left-hand side of keyboard.
- Repeated press f6, located on the top row of the keyboard.
- Tip: Repeating these steps pressing f5 will decrease the brightness.
Keyboard is Unresponsive
Keystrokes are not registering on laptop.
Keyboard is Disconnected From Display
Sometimes the entire keyboard is unresponsive. In this case, it is likely the keyboard has become disconnected from its display. Click HERE for a guide to replacing this connection.
Webcam Sees Nothing
Webcam does not turn on.
Webcam is Disabled/Disconnected
This laptop comes with a camera (at the top of the display) and webcam technology. Often times the user disables the webcam, and it needs to be re-enabled to function.
- Open the start menu in the bottom left corner of the desktop, or press the Windows key to open the same menu.
- Find the Device Manager by typing it into the search and selecting Device Manager from the list provided.
- Under Imaging Devices there should be an Integrated Camera.
- Right click on Integrated Camera and select enable from the menu.
Webcam Lens is Broken
Inspect the webcam at the top of your screen. If crack(s) can be seen replace camera lens.
0 comentarios
