Wiki con Contribuciónes de Estudiantes
Esta wiki ha sido creada por un increíble grupo de estudiantes de nuestro programa educativo.
Laptop Will Not Charge When Plugged In
Although plugged into a working outlet, battery level won’t increase when plugged in.
Faulty power cable/adapter
When plugged in, the computer will not display that it is charging. This will run the battery out. Consider purchasing a new power cable.
Faulty/Dead Battery
When plugged in, the computer will acknowledge that it is charging, but the battery level will not actually increase. Consider replacing the battery with a new one.
Unable To Get Internet Access
I cannot access the internet after booting my computer
Router Unable To Connect To Internet
If you can connect to your Wi-Fi, but your Wi-Fi cannot connect to the internet, then this is likely not a computer based problem but a router based one. Restarting your router may help, but if this does not work, calling your service provider may be required.
Unable To Connect To Router
If other networks are available, but your own network isn’t, then this is most likely an issue with your router. Restarting your router may help, but if this does not work, calling your service provider may be required.
Faulty Wi-Fi Card
If no Wi-Fi networks are available at all to connect to, and in most places there are, then this is most likely an issue with your Wi-Fi card. This can be fixed by replacing the Wi-Fi card, as shown here, or by purchasing a USB plug in Wi-Fi adapter.
Speaker Will Not Play Audio Out Loud
If audio is meant to be playing, but the computer is silent
The Computer is not outputting the audio through the speaker
Open the sound settings and look for the setting called “Output Device”. Check to see which device the computer is outputting to. Change the setting to output through your laptop’s speakers
Broken Speaker
The speaker on the computer may broken. To resolve this, replace the current speaker with a new unit.
Computer Will Not Boot
When pressing the power button, the computer does not boot
Faulty Battery
First, it’s important to check to see if your battery is working. Try plugging in your device and booting it again.
BIOS Error
This is an indication of a fatal failure in your computer. One way to attempt to resolve this is to attempt to replace the hard drive. If this does not work, the computer may be unusable.
Computer Will Not Read Discs
When a disc is inserted into the computer, the computer will not read that there is a disc or read any of the data from the disc
Damaged Disc
Check to see if your laptop has issues reading any other discs. Try several discs. If others work, but one particular one does not, it may be an issue with the disc itself. If this is the case, your computer is okay, but you may need to look into disc repair.
Damaged Disc Drive.
This could be an error with the disc drive. Try cleaning out the drive with a can of pressurized air. If that doesn’t work, try replacing the disc drive.
0 comentarios
