Saltar al contenido principal
Replacement de la vitre tactile et de l'écran LCD du Samsung Galaxy Note8
Qué necesitas
    • Insérer un commentaire.
Linea de Meta
21 personas más completaron esta guía.
ian mdx
Miembro Desde 06/30/16
8,968 Reputación
17 Guías creadas
9 comentarios
Am I to assume that I dont need to reapply or replace glue or adhesive strips? Is simply reheating the previous glue good enough to hold it?
Andrew Gross - Contestar
You might get away with re-heating the previously used glue the first time, however you may also notice the screen lifting from the frame. I would suggest using 99% Isopropyl alcohol to remove any excess or poorly positioned glue remaining after removing the LCD and re-applying a small amount of E8000 around the edges where there is glue missing. Posting this answer very late, but only because I know people are still repairing the Note8 using similar guides because it’s how I got here.
Jack Donovan -
note8 siyah ekran bozuldu. fiyat nedir
yasin tufekci - Contestar
Mine is coming up saying Note Network found after completion of the repair any ideas?
James Turner - Contestar
Will the phone remain waterproof after this repair?
cj-dm - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 4
Ultimos 30 días: 12
Todo El Tiempo: 24,044
