Saltar al contenido principal
Qué necesitas
Este desmontaje no es una guía de reparación. Para reparar tu Wiko Pulp 4G Phone, utiliza nuestros manuales de servicio .
  1. Wiko Pulp 4G Teardown, Wiko Pulp 4G Teardown: paso 1, imagen 1 de 3 Wiko Pulp 4G Teardown, Wiko Pulp 4G Teardown: paso 1, imagen 2 de 3 Wiko Pulp 4G Teardown, Wiko Pulp 4G Teardown: paso 1, imagen 3 de 3
    • So, what do we have here? This affordable smartphone offers some impressive specs at first glance:
    • Qualcomm® Snapdragon Quad-Core with 1.2 GHz
    • 2 GB RAM and 16 GB ROM (and additional Micro SD for up to 64 GB)
    • 5 inch IPS Display with 1280x720 pixels
    • 13 megapixels camera with 1080P video recording at 30 fps
    • USB OTG connection, a standard 3.5mm headphone jack, and an integrated Stereo FM Radio receiver
    • Android​ 5.1 Lollipop
    • Dual sim: 1 micro SIM + 1 nano SIM
  2. Wiko Pulp 4G Teardown: paso 2, imagen 1 de 3 Wiko Pulp 4G Teardown: paso 2, imagen 2 de 3 Wiko Pulp 4G Teardown: paso 2, imagen 3 de 3
    • We line a shift5.1 (left) up next to our Wiko Pulp 4G and see some similarities in their designs.
    • With the Wiko's official length measuring 143.9 mm from top to bottom, it is only 0.1 mm shorter than the shift5.1.
    • We played a very simple game of smart phone Jenga with the phones to see how their widths and thickness...stack up to each other.
    • Both have the same width: 72 mm. The Pulp4G, on top, is 8.8 mm thick, yet it appears thinner than the 7 mm of the shift 5.1, possibly due to its curved edges.
    • The back cover has a different look but is the same kind of snap off.
  3. Wiko Pulp 4G Teardown: paso 3, imagen 1 de 2 Wiko Pulp 4G Teardown: paso 3, imagen 2 de 2
    • Starting with the easily removable back cover we begin our journey towards the inside of this smartphone.
  4. Wiko Pulp 4G Teardown: paso 4, imagen 1 de 3 Wiko Pulp 4G Teardown: paso 4, imagen 2 de 3 Wiko Pulp 4G Teardown: paso 4, imagen 3 de 3
    • The user-removable Li-Po battery pops out with the move of a finger.
    • With 9.5 Wh (2500 mAh @ 3.8 V), it finds its place ahead of the iPhone 6 with 6.91 Wh (1810 mAh @ 3.82 V) and close behind the Galaxy S5 with 10.7 Wh (2800 mAh @ 3.85 V).
  5. Wiko Pulp 4G Teardown: paso 5, imagen 1 de 3 Wiko Pulp 4G Teardown: paso 5, imagen 2 de 3 Wiko Pulp 4G Teardown: paso 5, imagen 3 de 3
    Herramienta utilizada en este paso:
    Phillips #000 Screwdriver
    $5.49
    Comprar
    • The mid frame is held in place by eleven Phillips screws.
    • Having removed those screws we use our trusty plastic opening tool to pry away the mid frame.
  6. Wiko Pulp 4G Teardown: paso 6, imagen 1 de 2 Wiko Pulp 4G Teardown: paso 6, imagen 2 de 2
    • The only thing that remains inside the midframe is the rear facing loud speaker.
    • We are happy to see that it connects to the motherboard via spring contacts, allowing easy replacements in the future.
  7. Wiko Pulp 4G Teardown: paso 7, imagen 1 de 3 Wiko Pulp 4G Teardown: paso 7, imagen 2 de 3 Wiko Pulp 4G Teardown: paso 7, imagen 3 de 3
    • On the back of the display assembly we find the motherboard at the top section.
    • We take a moment to rejoice when we see all those ZIF connectors and bracket-covered press connectors. Then, start swiftly unlocking and unplugging them one by one.
  8. Wiko Pulp 4G Teardown: paso 8, imagen 1 de 3 Wiko Pulp 4G Teardown: paso 8, imagen 2 de 3 Wiko Pulp 4G Teardown: paso 8, imagen 3 de 3
    • First thing to come out is the small front facing camera which offers 5 megapixels.
    • Second in line is the big brother for the rear facing side which provides 13 megapixels for full HD video recording.
  9. Wiko Pulp 4G Teardown: paso 9, imagen 1 de 2 Wiko Pulp 4G Teardown: paso 9, imagen 2 de 2
    • One of the display cables still clings to the motherboard but can be peeled off easily.
    • Just two more Phillips screws to unscrew and we can take the board out for a close inspection.
  10. Wiko Pulp 4G Teardown: paso 10, imagen 1 de 2 Wiko Pulp 4G Teardown: paso 10, imagen 2 de 2
  11. Wiko Pulp 4G Teardown: paso 11, imagen 1 de 2 Wiko Pulp 4G Teardown: paso 11, imagen 2 de 2
    • IC Identification, Continued:
    • Qorvo RF1496A SP12T Antenna Switch
    • Skyworks SKY13416-485LF SP6T Antenna Switch
    • Texas Instruments TPD1S414 USB Charger OVP Switch w/ ESD Protection
    • ON Semiconductor NCP114AMX310T 300 mA/3.1 V LDO Regulator
    • Silergy DC-DC Converters
    • Likely Maxscend GNSS LNA
  12. Wiko Pulp 4G Teardown: paso 12, imagen 1 de 2 Wiko Pulp 4G Teardown: paso 12, imagen 2 de 2
    • Sensor identification:
    • TDK Invensense MPU-6881 3-Axis Accelerometer/Gyroscope
    • AKM Semiconductor AK09911 3-Axis Electronic Compass
    • Rohm BU52021HFV Hall Sensor
    • Proximity Sensor
  13. Wiko Pulp 4G Teardown: paso 13, imagen 1 de 3 Wiko Pulp 4G Teardown: paso 13, imagen 2 de 3 Wiko Pulp 4G Teardown: paso 13, imagen 3 de 3
    • Behind the mother board we remove a rubber gasket that goes around the headphone jack and holds the lens for the LED flash.
    • Last part at the top section is the earpiece speaker.
  14. Wiko Pulp 4G Teardown: paso 14, imagen 1 de 3 Wiko Pulp 4G Teardown: paso 14, imagen 2 de 3 Wiko Pulp 4G Teardown: paso 14, imagen 3 de 3
    • At the bottom of the display assembly we find a daughter board with some components.
    • First we disconnect the cable coming from the motherboard and pry out the vibrator.
    • Next we peel off a small connector plate and disconnect the antenna cable.
    • Now we are ready to carefully pry out the daughter board itself which is glued in with some double sided tape.
  15. Wiko Pulp 4G Teardown: paso 15, imagen 1 de 2 Wiko Pulp 4G Teardown: paso 15, imagen 2 de 2
    • Being able to detach the daughter board completely from the cable (and therefore from the mother board) is a big advantage over the shift5.1.
    • On the other hand, all of the components are soldered to the board, which makes repairing them individually a bit trickier.
    • USB port
    • Vibrator
    • Microphone
  16. Wiko Pulp 4G Teardown: paso 16, imagen 1 de 2 Wiko Pulp 4G Teardown: paso 16, imagen 2 de 2
    • Speaking of the connection cable, we peel off the big sticker and find the second display cable running underneath and directly into the display itself.
    • With the sticker gone it is possible to also take away the power and volume buttons.
    • We stop here, leaving the connector cable in place.
  17. Wiko Pulp 4G Teardown: paso 17, imagen 1 de 1
    • We take a moment and sum up what we've discovered.
  18. Consideraciones Finales
    • Replacing the battery is easy as pie with the swappable back cover.
    • This phone doesn't use excessive glue nor proprietary screws—we found only Phillips throughout the entirety.
    • Most of the components can be replaced separately.
    • The motherboard and daughterboard are connected via a detachable cable.
    • Unfortunately, the components on the daughterboard are soldered on, making a repair on an individual component difficult.
    Calificación de Reparabilidad
    7
    Reparabilidad 7 de 10
    (10 es lo más fácil de reparar)
Tobias Isakeit
Miembro Desde 03/31/14
116,767 Reputación
188 Guías creadas
Equipo
Master Techs Miembro de Master Techs
Community
322 Miembros
2,506 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 20
Todo El Tiempo: 10,304
