Introducción
This guide will help you to completely disassemble your phone in order to perform other repairs.
Este desmontaje no es una guía de reparación. Para reparar tu Uniden EXP 371, utiliza nuestros manuales de servicio .
Uniden EXP371 900 MHz Cordless Phone.
  • Uniden EXP371 900 MHz Cordless Phone.
  • 900 MHz Extended Range with One Touch RocketDial/Find Handset Locator and is Desk or Wall Mountable.
Agregar Comentario
Remove the battery by first pressing down on the rear of the cover and pushing the cover towards the bottom of the phone. Next remove the battery by pulling on the connector.
  • Remove the battery by first pressing down on the rear of the cover and pushing the cover towards the bottom of the phone.
  • Next remove the battery by pulling on the connector.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Next remove the two screws at the bottom of the phone with a PH1 philips screwdriver. Now remove the top portion of the case from the bottom.  This may be difficult to do with your bare hands. The use of a plastic opening tool may come in handy.
  • Next remove the two screws at the bottom of the phone with a PH1 philips screwdriver.
  • Now remove the top portion of the case from the bottom. This may be difficult to do with your bare hands. The use of a plastic opening tool may come in handy.
Agregar Comentario
Your next step is to remove the five screws holding down the motherboard.  Use the PH1 philips screwdriver. Once you have removed the five screws you may lift the motherboard off of the front case. At this point you may also remove the dial pad. It simply lifts off.
  • Your next step is to remove the five screws holding down the motherboard. Use the PH1 philips screwdriver.
  • Once you have removed the five screws you may lift the motherboard off of the front case.
  • At this point you may also remove the dial pad. It simply lifts off.
  • You may also remove the speaker if needed by unscrewing the two screws using the PH1 philips screwdriver.
  • The whole phone is now disassembled at this point.
Agregar Comentario
Tim Reimer
Miembro Desde 19/06/10
164 Reputación
3 Guías creadas
this guide is poorly written, please delete or improve it.
Walker Quine - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 5
Todo El Tiempo: 4,323
