Saltar al contenido principal
Tungsten E Disassembly
Qué necesitas
  1. Tungsten E Disassembly, Tungsten E Disassembly: paso 1, imagen 1 de 2 Tungsten E Disassembly, Tungsten E Disassembly: paso 1, imagen 2 de 2
    • Remove the stylus and SD card.
    • Using a T5 torx screwdriver, remove all 4 back panel screws.
    • The screws are small and can be lost easily. Be sure to place them in a secure area.
  2. Tungsten E Disassembly: paso 2, imagen 1 de 3 Tungsten E Disassembly: paso 2, imagen 2 de 3 Tungsten E Disassembly: paso 2, imagen 3 de 3
    • Insert a plastic opening tool under the USB and power input slots.
    • Slide the plastic opener along the seam and gently pry the cover from the PDA body to remove the cover completely.
  3. Tungsten E Disassembly: paso 3, imagen 1 de 2 Tungsten E Disassembly: paso 3, imagen 2 de 2
    • Your device may not have a screen protector. If not, you can move on to step four.
    • Remove the screen protector by lifting the hinge out of the plastic housing.
    • Remove the top cover by gently pulling it away from the device with a plastic opening tool or your fingers.
  4. Tungsten E Disassembly: paso 4, imagen 1 de 2 Tungsten E Disassembly: paso 4, imagen 2 de 2
    • Carefully remove motherboard from the standoffs without damaging the LCD flex connector.
    • Using a spudger, unlock both sides of the flex connector block by pushing down.
    • Remove motherboard completely.
    • Metal washers may pop out of the device during this step
  5. Tungsten E Disassembly: paso 5, imagen 1 de 3 Tungsten E Disassembly: paso 5, imagen 2 de 3 Tungsten E Disassembly: paso 5, imagen 3 de 3
    • Remove buttons using fingers.
    • Gently flex frame to release screen from plastic frame.
    • Lift out screen.
  6. Tungsten E Disassembly: paso 6, imagen 1 de 1
    • Congratulations! You have successfully taken apart a Palm Tungsten E.
Conclusión
Kevin Hom
Miembro Desde 01/21/10
103 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 13-22, Maness Winter 2010 Miembro de Cal Poly, Team 13-22, Maness Winter 2010
CPSU-MANESS-W10S13G22
4 Miembros
4 Guías creadas
Un comentario
How does one unplug the battery?
dlcatftwin - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 26
Todo El Tiempo: 7,809
