Herramientas Destacadas en este Teardown
Introducción
Provided is an exploded view of the TI-92 calculator. All dis-assembled components are the back-side of the parts.
Este desmontaje no es una guía de reparación. Para reparar tu Texas Instruments TI-92, utiliza nuestros manuales de servicio .
Remove the protective cover. This will easily unsnap from the main body.
  • Remove the protective cover. This will easily unsnap from the main body.
Agregar Comentario
Slide the tab located at the top of the calculator to the unlocked position.
  • Slide the tab located at the top of the calculator to the unlocked position.
Agregar Comentario
Slide the back cover down, and then pull the back plate away from the calculator.
  • Slide the back cover down, and then pull the back plate away from the calculator.
Agregar Comentario
Unscrew the back-up battery cover. (1 screw)
  • Unscrew the back-up battery cover. (1 screw)
Agregar Comentario
Remove all visible screws.
  • Remove all visible screws.
    • Note that there are more screws than shown in this picture (16 in total). You MUST remove them ALL.
Agregar Comentario
Keeping the front faceplate FACE DOWN on the work surface, lift the circuit board AND the plastic backing up and away from the faceplate.
  • Keeping the front faceplate FACE DOWN on the work surface, lift the circuit board AND the plastic backing up and away from the faceplate.
Agregar Comentario
These two components are loosely attached by the rectangular module just below the back-up battery.
  • These two components are loosely attached by the rectangular module just below the back-up battery.
Agregar Comentario
The warning label next to this module reads "Do not remove the rectangular module located under the test access panel as it is required for proper product operation!"
  • The warning label next to this module reads "Do not remove the rectangular module located under the test access panel as it is required for proper product operation!"
Agregar Comentario
The rubber mat in back of the faceplate may be removed, exposing all 77 individual plastic keys.
  • The rubber mat in back of the faceplate may be removed, exposing all 77 individual plastic keys.
  • CAUTION: These keys are loosely held in by gravity and will fall out if the faceplate is tilted to any extreme.
Agregar Comentario
The device has now been separated into as many component parts as intended by the manufacturer.
  • The device has now been separated into as many component parts as intended by the manufacturer.
Agregar Comentario
Equipo
Cal Poly, Team 15-51, Garner Spring 2010 Miembro de Cal Poly, Team 15-51, Garner Spring 2010
CPSU-GARNER-S10S15G51
5 Miembros
9 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 2
Últimos 30 Días: 5
Todo El Tiempo: 7,870
