Introducción
This is actually a reverse teardown -- a build-up, you could say -- of a Suzuki FA50's throttle cable. This was the best method I could think of to describe the stuck throttle cable problem I've been experiencing with my moped.
Este desmontaje no es una guía de reparación. Para reparar tu Suzuki FA50 Moped, utiliza nuestros manuales de servicio .
Here is the assembled throttle cable. It seems to be assembled correctly, but certainly does not function properly.
  • Here is the assembled throttle cable. It seems to be assembled correctly, but certainly does not function properly.
Agregar Comentario
The throttle parts. The only logical way for me to assemble these parts were:
  • The throttle parts.
  • The only logical way for me to assemble these parts were:
    • Insert needle into gold-colored cylinder.
    • Insert retaining clip on top of needle.
    • Then compress and insert the spring (see following steps on how the spring was inserted).
Agregar Comentario
The throttle cable without any parts.
  • The throttle cable without any parts.
  • The round, gray top screws into the carburetor.
Agregar Comentario
To assemble the throttle cable:
  • To assemble the throttle cable:
    • I first use a pair of needle-nose pliers to compress the spring as much as I can.
    • This allows me to insert the throttle cable into the gold-colored cylinder without having to meddle with the spring too much.
Agregar Comentario
I attach the throttle cable to the bottom of the gold cylinder and then route it through the cylinder's side slot. The alternate view (picture 2) shows how everything looks internally.
  • I attach the throttle cable to the bottom of the gold cylinder and then route it through the cylinder's side slot.
  • The alternate view (picture 2) shows how everything looks internally.
  • After the throttle cable is in place, I let go of the spring into the cylinder.
Agregar Comentario
I'm simulating screwing on the throttle to the carburetor by compressing the gold cylinder against the gray cap. As you can see, the spring compresses, and the throttle cable pops outward. When I twist the moped's throttle, the throttle cable goes inwards. I believe this is the desired action for the cable.
  • I'm simulating screwing on the throttle to the carburetor by compressing the gold cylinder against the gray cap. As you can see, the spring compresses, and the throttle cable pops outward.
  • When I twist the moped's throttle, the throttle cable goes inwards. I believe this is the desired action for the cable.
  • There are two problems, however:
    • Nothing pushes the throttle cable back out when I release the moped's throttle.
    • The throttle needle does not move, but to my understanding it should go upward when I apply the throttle.
  • Please check out my Answers question if you can help me solve this problem! Thanks a lot!
Agregar Comentario
which way does you set the throttle when you put it in
ladell - Contestar
It appears to be correctly assembled however the cable isn't bottomed out on the cup to allow for free movement, I think you may have put a flat spot in to the cable itself that's not allowing the cup to bottom out on it and giving you the return movement.
Ken James - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 3
Últimos 7 Días: 19
Últimos 30 Días: 97
Todo El Tiempo: 9,411
