Herramientas Destacadas en este Teardown
Introducción
This guide will walk you through the steps to completely disassemble a Sprint Airave.
Este desmontaje no es una guía de reparación. Para reparar tu Sprint Airave SCS-26UC2, utiliza nuestros manuales de servicio .
Remove the external antenna, GPS cover, and GPS module. Remove the external antenna, GPS cover, and GPS module. Remove the external antenna, GPS cover, and GPS module.
  • Remove the external antenna, GPS cover, and GPS module.
Agregar Comentario
Use a pry tool to remove the white outer cover. Pry towards the front of the device. Continue prying down the length of the cover until it pops off. Use a pry tool to remove the white outer cover. Pry towards the front of the device. Continue prying down the length of the cover until it pops off. Use a pry tool to remove the white outer cover. Pry towards the front of the device. Continue prying down the length of the cover until it pops off.
  • Use a pry tool to remove the white outer cover. Pry towards the front of the device. Continue prying down the length of the cover until it pops off.
Agregar Comentario
Locate and remove the four Phillips screws
  • Locate and remove the four Phillips screws
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
With the cover removed you now have access to the circuit board.
  • With the cover removed you now have access to the circuit board.
Agregar Comentario
Using an 8mm socket you can remove the antenna pigtail.
  • Using an 8mm socket you can remove the antenna pigtail.
Agregar Comentario
Release the clip indicate to remove the circuit board.
  • Release the clip indicate to remove the circuit board.
Agregar Comentario
Here is the circuit board fully removed. Here is the circuit board fully removed.
  • Here is the circuit board fully removed.
Agregar Comentario
Erik Leonard
Miembro Desde 11/06/11
164 Reputación
1 Guía escrita
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 2
Últimos 30 Días: 4
Todo El Tiempo: 2,983
