Saltar al contenido principal
Qué necesitas
Este desmontaje no es una guía de reparación. Para reparar tu Speakal iPanda, utiliza nuestros manuales de servicio .
  1. Speakal iPanda Teardown, Speakal iPanda Teardown: paso 1, imagen 1 de 1
    • The happy Panda
  2. Speakal iPanda Teardown: paso 2, imagen 1 de 3 Speakal iPanda Teardown: paso 2, imagen 2 de 3 Speakal iPanda Teardown: paso 2, imagen 3 de 3
    • Flip it to find the screws.
    • Unscrew the four Phillips #0 screws.
  3. Speakal iPanda Teardown: paso 3, imagen 1 de 2 Speakal iPanda Teardown: paso 3, imagen 2 de 2
    • Be careful with the cables of the subwoofer.
  4. Speakal iPanda Teardown: paso 4, imagen 1 de 2 Speakal iPanda Teardown: paso 4, imagen 2 de 2
    • He look like this on his insides.
    • there is a little lock on the sides.
    • Don't forget these screws too.
  5. Speakal iPanda Teardown: paso 5, imagen 1 de 2 Speakal iPanda Teardown: paso 5, imagen 2 de 2
    • Opening the sandwich.
    • Don't forget the cables!
  6. Speakal iPanda Teardown: paso 6, imagen 1 de 3 Speakal iPanda Teardown: paso 6, imagen 2 de 3 Speakal iPanda Teardown: paso 6, imagen 3 de 3
    • It doens't look like a panda anymore.
  7. Speakal iPanda Teardown: paso 7, imagen 1 de 1
    • Removing the board, it's all done.
  8. Speakal iPanda Teardown: paso 8, imagen 1 de 2 Speakal iPanda Teardown: paso 8, imagen 2 de 2
    • Poor panda...
paulostool
Miembro Desde 06/06/11
121 Reputación
1 Guía escrita
3 comentarios
Hi!
I have just wondered about tweeter type.
I have a pig, bud one of it's tweeters is dead.
Do you have any idea how to get a replacement tweeter?
THX!!
sonofhoegaarden - Contestar
Hello All,
Please can you assist me with sourcing a amplifier board for the Shox Panda as above in the panda tear down. My panda is supplying 12 Vots DC to the woofer. Thanks very much.
Peter Boucher - Contestar
Hi Peter, you may consider swapping the actual CD7377CZ Audio Amp for a ST Microelectronics TDA7375V, and probably the RM2576-5.0 voltage regulator with a Texas Instruments LM2576-5.0, both of which are drop-in replacement (as parts are chinese knock-offs).
Cheers !
grogcw - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 4
Todo El Tiempo: 5,047
