Este desmontaje no es una guía de reparación. Para reparar tu Sony Ericsson K750i, utiliza nuestros manuales de servicio .
Remove battery cover
  • Remove battery cover
    • Press down firmly with thumb and slide cover back
Agregar Comentario
Remove 4 screws from battery chamber
  • Remove 4 screws from battery chamber
    • Red - Phillips 0 screwdriver
    • Blue - Torx 6 screwdriver
Agregar Comentario
Gently pry off back casing
  • Gently pry off back casing
    • Note: work shim or flathead screwdriver around entire seam before attempting to pull off casing. This will reduce the chance of cracking the casing.
Agregar Comentario
Remove casing to expose camera components
  • Remove casing to expose camera components
Agregar Comentario
Gently pry open front casing by working a small shim or flathead screwdriver along the entire seam
  • Gently pry open front casing by working a small shim or flathead screwdriver along the entire seam
Agregar Comentario
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Remove front casing by gently lifting it from the phone
  • Remove front casing by gently lifting it from the phone
    • Be careful not to pull off any other delicate pieces
Agregar Comentario
Keypad should be easy to remove Caution: LCD screen is very fragile. Be careful not to catch the keypad on it while removing.
  • Keypad should be easy to remove
    • Caution: LCD screen is very fragile. Be careful not to catch the keypad on it while removing.
Agregar Comentario
Remove screws holding the screen in place
  • Remove screws holding the screen in place
Agregar Comentario
Gently lift the base of the keypad to remove it
  • Gently lift the base of the keypad to remove it
Agregar Comentario
Gently pull up the green film.
  • Gently pull up the green film.
    • Avoid the joystick
    • The LCD screen will be attached to this film and come off with it.
  • Caution: LCD screen is very fragile. Handle with care.
Agregar Comentario
Slide ribbon out of its connection
  • Slide ribbon out of its connection
Agregar Comentario
Lift the motherboard out of the phone Caution: Ribbon is fragile.  Work motherboard off around the ribbon to prevent damage
  • Lift the motherboard out of the phone
    • Caution: Ribbon is fragile. Work motherboard off around the ribbon to prevent damage
Agregar Comentario
Pry off microchip below the ribbon Pry off microchip below the ribbon
  • Pry off microchip below the ribbon
Agregar Comentario
Lift out plastic support Teardown is complete
  • Lift out plastic support
  • Teardown is complete
Agregar Comentario
Abby Evers
Miembro Desde 04/10/11
196 Reputación
12 Guías creadas
Equipo
UW Stout, Team 1-6, Zhou Fall 2011 Miembro de UW Stout, Team 1-6, Zhou Fall 2011
UWSTOUT-ZHOU-F11S1G6
4 Miembros
12 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 6
Últimos 30 Días: 33
Todo El Tiempo: 10,416
