Saltar al contenido principal
Qué necesitas
Este desmontaje no es una guía de reparación. Para reparar tu Samsung Intensity, utiliza nuestros manuales de servicio .
  1. Samsung Intensity Teardown, Samsung Intensity Teardown: paso 1, imagen 1 de 1
    • Remove the back cover and battery
  2. Samsung Intensity Teardown: paso 2, imagen 1 de 1
    • Remove the 8 screw that hold the back cover down.
    • Carefully pry back piece off
    • Start at the bottom and work toward the top.
  3. Samsung Intensity Teardown: paso 3, imagen 1 de 1
    • Use the ipod opening tool to disconnect the Connector
  4. Samsung Intensity Teardown: paso 4, imagen 1 de 2 Samsung Intensity Teardown: paso 4, imagen 2 de 2
    • Carefully remove the main board
    • Make sure to not tear the microphone cable, pry it from the phone carefully
  5. Samsung Intensity Teardown: paso 5, imagen 1 de 2 Samsung Intensity Teardown: paso 5, imagen 2 de 2
    • Remove the 6 screws
    • Pry to ribbon cable assembly loose from the slider
    • Its glued on the left and right side
  6. Samsung Intensity Teardown: paso 6, imagen 1 de 1
    • Remove the 4 screw the holds the slider to the phone assembly
    • one of the screws will be behind the hinge
    • Carefully pry slider assembly loose from display assembly
  7. Samsung Intensity Teardown: paso 7, imagen 1 de 3 Samsung Intensity Teardown: paso 7, imagen 2 de 3 Samsung Intensity Teardown: paso 7, imagen 3 de 3
    • Remove the tape and pop the connectors and pull all the ribbon cables loose
    • Carefully pry the speaker loose from the case.
  8. Samsung Intensity Teardown: paso 8, imagen 1 de 1
    • Carefully work the keyboard loose from the display assembly
    • There are a couple fragile clips that hold it in place
  9. Samsung Intensity Teardown: paso 9, imagen 1 de 2 Samsung Intensity Teardown: paso 9, imagen 2 de 2
    • LCD comes out pretty easily
    • Pry it from the bottom and work up the sides to release it if stuck
    • The glass can be removed with a little heat from a heat gun or blow dryer
    • Pry it out from the outside edges working around carefully
David
Miembro Desde 08/10/11
148 Reputación
1 Guía escrita
Equipo
West Georgia Technology Miembro de West Georgia Technology
Business
1 Miembro
1 Guía escrita
Un comentario
This was so helpful! How can I show my gratitude to you for these helpful instructions?
teh_pwnerer22 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 25
Todo El Tiempo: 4,700
