Saltar al contenido principal
Qué necesitas
Este desmontaje no es una guía de reparación. Para reparar tu Samsung Galaxy S, utiliza nuestros manuales de servicio .
  1. Samsung Galaxy S Teardown, Samsung Galaxy S Teardown: paso 1, imagen 1 de 1
    • The phone itself!
    • Notice the bad lighting, dirty phone etc. just proves how hi-tec i am.
  2. Samsung Galaxy S Teardown: paso 2, imagen 1 de 3 Samsung Galaxy S Teardown: paso 2, imagen 2 de 3 Samsung Galaxy S Teardown: paso 2, imagen 3 de 3
    • Removing the boring stuff. Back cover, battery etc.
  3. Samsung Galaxy S Teardown: paso 3, imagen 1 de 2 Samsung Galaxy S Teardown: paso 3, imagen 2 de 2
    • The battery!
    • It shows 1500mAh, decent.
    • also the manufacturing date is shown.
    • I added a piece of sticky tack, to cover up the IMEI code, again showing how hi-tec i am!
  4. Samsung Galaxy S Teardown: paso 4, imagen 1 de 2 Samsung Galaxy S Teardown: paso 4, imagen 2 de 2
    • This is the point of no return when it comes to warranty.
    • But that's okay, i'm using this phone for spares anyways.
    • Sticky tack
    • Screws, 7 to be exact!
  5. Samsung Galaxy S Teardown: paso 5, imagen 1 de 2 Samsung Galaxy S Teardown: paso 5, imagen 2 de 2
    • Here comes the first tricky part. it's easiest to start right under the volume button, and work your way from there.
    • Be extremely careful if you are using metal tools like i am. it will easily damage components if you accidentally jam it in.
    • And it's off!
  6. Samsung Galaxy S Teardown: paso 6, imagen 1 de 3 Samsung Galaxy S Teardown: paso 6, imagen 2 de 3 Samsung Galaxy S Teardown: paso 6, imagen 3 de 3
    • Lets see the innards of this thing.
    • The back camera.
    • And the front facing camera
    • The speaker, actually quite large.
    • Water detector on the plastic cover, as you can see, this is a water damaged phone. normally you would see a purple pattern.
    • Contacts, probably for antennas.
  7. Samsung Galaxy S Teardown: paso 7, imagen 1 de 2 Samsung Galaxy S Teardown: paso 7, imagen 2 de 2
    • Better close ups of the components.
    • Vibration motor
  8. Samsung Galaxy S Teardown: paso 8, imagen 1 de 3 Samsung Galaxy S Teardown: paso 8, imagen 2 de 3 Samsung Galaxy S Teardown: paso 8, imagen 3 de 3
    • Taking off the speaker.
    • Remember to lift the tab on me!
    • And it's off!
  9. Samsung Galaxy S Teardown: paso 9, imagen 1 de 3 Samsung Galaxy S Teardown: paso 9, imagen 2 de 3 Samsung Galaxy S Teardown: paso 9, imagen 3 de 3
    • Now for the camera!
    • Both the rear and front camera are a single component.
    • Lift the connector in picture 2 carefully! lots of components under it.
  10. Samsung Galaxy S Teardown: paso 10, imagen 1 de 2 Samsung Galaxy S Teardown: paso 10, imagen 2 de 2
    • Now for the motherboard!
    • Detach all (4) of these to get the motherboard out.
    • Done! (do not try to remove yet)
  11. Samsung Galaxy S Teardown: paso 11, imagen 1 de 2 Samsung Galaxy S Teardown: paso 11, imagen 2 de 2
    • Now detach the power button, its held down by a little bit of glue, not a big deal.
    • Lift it carefully, making sure no connectors are stuck on. Especially the one marked red.
  12. Samsung Galaxy S Teardown: paso 12, imagen 1 de 2 Samsung Galaxy S Teardown: paso 12, imagen 2 de 2
    • Front/back
    • Flash memory.
    • CPU running at 1Ghz, but can be overclocked.
    • Volume buttons.
    • Ill add more specific specs when i get around to it.
  13. Samsung Galaxy S Teardown: paso 13, imagen 1 de 3 Samsung Galaxy S Teardown: paso 13, imagen 2 de 3 Samsung Galaxy S Teardown: paso 13, imagen 3 de 3
    • Removing the cable for sim/sd card slot..
    • And it's off.
    • Bad white balance, sorry!
  14. Samsung Galaxy S Teardown: paso 14, imagen 1 de 2 Samsung Galaxy S Teardown: paso 14, imagen 2 de 2
    • The simcard/sd card slot.
    • And the stuff underneath.
  15. Samsung Galaxy S Teardown: paso 15, imagen 1 de 3 Samsung Galaxy S Teardown: paso 15, imagen 2 de 3 Samsung Galaxy S Teardown: paso 15, imagen 3 de 3
    • Now for the metal Shielding on the back! again, more specs coming (hopefully) soon.
  16. Samsung Galaxy S Teardown: paso 16, imagen 1 de 1
    • Parts parts parts!
    • And a bad white balance..
  17. Samsung Galaxy S Teardown: paso 17, imagen 1 de 3 Samsung Galaxy S Teardown: paso 17, imagen 2 de 3 Samsung Galaxy S Teardown: paso 17, imagen 3 de 3
    • Now for the component that holds the headphone jack, earpiece and both proximity and light sensor.
    • There is a cool app "androsensor" that lets you access all the sensors in your phone!
    • This thing quite literally just pulls off. you can remove it without any special tools!
    • Be careful not to tug on the cables too hard! there is some glue, but it peels right off.
  18. Samsung Galaxy S Teardown: paso 18, imagen 1 de 2 Samsung Galaxy S Teardown: paso 18, imagen 2 de 2
    • Now for the bottom portion, including the Mic, vibrating engine and the antenna board.
    • I couldn't get it off completely, but i can give you a good picture of what it looks, lets see..
    • We seem to be connected together!
  19. Samsung Galaxy S Teardown: paso 19, imagen 1 de 3 Samsung Galaxy S Teardown: paso 19, imagen 2 de 3 Samsung Galaxy S Teardown: paso 19, imagen 3 de 3
    • Disconnect, unplug, take off..
  20. Samsung Galaxy S Teardown: paso 20, imagen 1 de 3 Samsung Galaxy S Teardown: paso 20, imagen 2 de 3 Samsung Galaxy S Teardown: paso 20, imagen 3 de 3
    • Be extremely careful when taking off these little boards, they're on tight! and they like to bend around.
  21. Samsung Galaxy S Teardown: paso 21, imagen 1 de 3 Samsung Galaxy S Teardown: paso 21, imagen 2 de 3 Samsung Galaxy S Teardown: paso 21, imagen 3 de 3
    • see that? the AMOLED display is actually transparent!
    • Can't go farther than this without a heat gun that I don't have. I tried removing the bezel, but with no luck.
    • That's about it! Thank you for reading, and please give me feedback!
    • This is my first teardown, and pictures were taken with a functional Galaxy s phone.
valtteri
Miembro Desde 11/18/11
839 Reputación
1 Guía escrita
8 comentarios
I would like to replace just the front lens of the phone , cuz the old one got cracked, can you do a tutorial on that , do I have to teardown the hole phone to replace the front panel without the digitizer.
Samsung galaxy s1 i900
Kasavin Drago - Contestar
You have come a long way from this tear down to the ones done now!
Shreyas Bharadwaj - Contestar
thank you. my son broke his Galaxy S sim card pins(third smart phone in five months!!!) and I am hoping to repair it myself with the help of your fix-it.Will let you know if I succeed.Margaret, April 2014.
margaret - Contestar
Hi I dropped my phone and it the glasses shattered and totally shutdown when dead on me. Wondering any hope for repairs?
Nabikaly - Contestar
What is the part number of the Bluetooth Chip here?Manufacturer?
Raul Piper - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 63
Todo El Tiempo: 65,314
