Saltar al contenido principal
Qué necesitas
Este desmontaje no es una guía de reparación. Para reparar tu Samsung GT-E2120, utiliza nuestros manuales de servicio .
  1. Samsung GT-E2120 Teardown, Samsung GT-E2120 Teardown: paso 1, imagen 1 de 1
    • Before you begin it's always good to ground yourself to eliminate the risk for shock.
  2. Samsung GT-E2120 Teardown: paso 2, imagen 1 de 2 Samsung GT-E2120 Teardown: paso 2, imagen 2 de 2
    • Using your thumb, press down on the back of the device in a downward motion to open the back cover.
    • Remove the battery along with the sim card and Micro-SD card.
    • This phone can take up to a 2GB Micro-SD card and is great for storing music. It even has a FM radio!
  3. Samsung GT-E2120 Teardown: paso 3, imagen 1 de 2 Samsung GT-E2120 Teardown: paso 3, imagen 2 de 2
    • Next, using a Philips screwdriver, remove the five screws from the back of the device.
  4. Samsung GT-E2120 Teardown: paso 4, imagen 1 de 3 Samsung GT-E2120 Teardown: paso 4, imagen 2 de 3 Samsung GT-E2120 Teardown: paso 4, imagen 3 de 3
    • For this step a matal spudger is used to release the clips along the bottom, top, and sides of the phone.
    • These clips can be found at the points marked in red.
    • Working from the top down, gently prying at the case the clips are easily dislodged.
  5. Samsung GT-E2120 Teardown: paso 5, imagen 1 de 2 Samsung GT-E2120 Teardown: paso 5, imagen 2 de 2
    • When the bottom of the phone is reached it is a bit harder to pull the bottom clips off.
    • This can be made a tad easier by using the pointed end of the spudger to get in and under the case.
    • Once the case is lifted up slightly, you can get enough purchase under the clip and lift it off.
    • Be careful so you dont damage the motherboard!
  6. Samsung GT-E2120 Teardown: paso 6, imagen 1 de 1
    • This images shows the two halves separated.
    • The camera located in the blue square is a VGA 640X480 resolution color camera.
  7. Samsung GT-E2120 Teardown: paso 7, imagen 1 de 2 Samsung GT-E2120 Teardown: paso 7, imagen 2 de 2
    • The microphone is carefully lifted from its bracket, and the motherboard is carefully removed.
  8. Samsung GT-E2120 Teardown: paso 8, imagen 1 de 1
    • Then the keyboard is simply pushed out.
    • The Phone includes a 65K CSTN color screen with a 128X128 resolution.
Michael C
Miembro Desde 01/09/11
410 Reputación
1 Guía escrita
Equipo
OPEN Miembro de OPEN
Community
82 Miembros
25 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 12
Todo El Tiempo: 14,025
