Este desmontaje no es una guía de reparación. Para reparar tu Rubik's Cube, utiliza nuestros manuales de servicio .
Turn the top row so that each corner is roughly halfway between the sides Push the pieces up until they pop out of the cube, then, slide the rest out Repeat this process until you clear the level
  • Turn the top row so that each corner is roughly halfway between the sides
  • Push the pieces up until they pop out of the cube, then, slide the rest out
  • Repeat this process until you clear the level
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
You should be able to just directly pull out the rest of the blocks, like so And there you have it!
  • You should be able to just directly pull out the rest of the blocks, like so
  • And there you have it!
  • You'll have the center piece, with the six centers of the six sides, the turning mechanism
Agregar Comentario
To reassemble, snap all the pieces back into place, and try not to rotate the faces. It helps to start with the middle pieces first
  • To reassemble, snap all the pieces back into place, and try not to rotate the faces.
  • It helps to start with the middle pieces first
  • Don't be afraid to use force!
  • Once you have the middle pieces in it's pretty simple to just push in the corner pieces
  • Again- don't be afraid to use force!
Agregar Comentario
rab777hp
Miembro Desde 17/11/09
20,233 Reputación
7 Guías creadas
Equipo
OPEN Miembro de OPEN
Community
74 Miembros
15 Guías creadas
I hated this thing. I disassembled mine with a .22 hollow point at 100 yards. Yes, It felt great!
mpias - Contestar
lol don’t blame you, can’t stand the thing
Luke Legg -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 5
Últimos 7 Días: 33
Últimos 30 Días: 154
Todo El Tiempo: 17,518
