Saltar al contenido principal
Qué necesitas
Este desmontaje no es una guía de reparación. Para reparar tu Rubik's Cube, utiliza nuestros manuales de servicio .
  1. Rubik's Cube Teardown, Rubik's Cube Teardown: paso 1, imagen 1 de 3 Rubik's Cube Teardown, Rubik's Cube Teardown: paso 1, imagen 2 de 3 Rubik's Cube Teardown, Rubik's Cube Teardown: paso 1, imagen 3 de 3
    • Turn the top row so that each corner is roughly halfway between the sides
    • Push the pieces up until they pop out of the cube, then, slide the rest out
    • Repeat this process until you clear the level
  2. Rubik's Cube Teardown: paso 2, imagen 1 de 2 Rubik's Cube Teardown: paso 2, imagen 2 de 2
    • You should be able to just directly pull out the rest of the blocks, like so
    • And there you have it!
    • You'll have the center piece, with the six centers of the six sides, the turning mechanism
  3. Rubik's Cube Teardown: paso 3, imagen 1 de 2 Rubik's Cube Teardown: paso 3, imagen 2 de 2
    • To reassemble, snap all the pieces back into place, and try not to rotate the faces.
    • It helps to start with the middle pieces first
    • Don't be afraid to use force!
    • Once you have the middle pieces in it's pretty simple to just push in the corner pieces
    • Again- don't be afraid to use force!
rab777hp
Miembro Desde 11/17/09
20,333 Reputación
3 Guías creadas
Equipo
OPEN Miembro de OPEN
Community
82 Miembros
25 Guías creadas
6 comentarios
I hated this thing. I disassembled mine with a .22 hollow point at 100 yards. Yes, It felt great!
mpias - Contestar
lol don’t blame you, can’t stand the thing
Luke -
that method just broke my rubiks my cube.. thanks anyway
hamzamagdy888 - Contestar
my middle peices came out cant fix it
jax - Contestar
can someone tell me how to fix it
jax - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 11
Ultimos 30 días: 29
Todo El Tiempo: 24,546
