Saltar al contenido principal
Qué necesitas
Este desmontaje no es una guía de reparación. Para reparar tu Rowenta AC6221, utiliza nuestros manuales de servicio .
  1. Rowenta AC6221 Teardown, Rowenta AC6221 Teardown: paso 1, imagen 1 de 3 Rowenta AC6221 Teardown, Rowenta AC6221 Teardown: paso 1, imagen 2 de 3 Rowenta AC6221 Teardown, Rowenta AC6221 Teardown: paso 1, imagen 3 de 3
    • The 4.8 Rowenta vacuum can be used for a variety of purposes.
    • It is charged through its pedestal. The power of the pedestal is:
    • Input: 230V - 50 Hz - 7W (AC)
    • Output: 7.5V - 300 mA (DC)
  2. Rowenta AC6221 Teardown: paso 2, imagen 1 de 3 Rowenta AC6221 Teardown: paso 2, imagen 2 de 3 Rowenta AC6221 Teardown: paso 2, imagen 3 de 3
    • This vacuum has several parts:
    • The tip
    • The reservoir which holds the dust and debris
    • The engine (4.8V)
    • The pedestal
    • The power supply
    • From top to bottom, the reservoir contains 3 parts: the housing, container, and filter.
  3. Rowenta AC6221 Teardown: paso 3, imagen 1 de 3 Rowenta AC6221 Teardown: paso 3, imagen 2 de 3 Rowenta AC6221 Teardown: paso 3, imagen 3 de 3
    • Remove the two outer Philips #00 screws from the bottom of the engine.
    • The back of the circuit board will now be visible.
  4. Rowenta AC6221 Teardown: paso 4, imagen 1 de 3 Rowenta AC6221 Teardown: paso 4, imagen 2 de 3 Rowenta AC6221 Teardown: paso 4, imagen 3 de 3
    • Remove the two inner screws.
    • Insert a flat screwdriver between the cover and the base of the engine and remove the cover.
    • The wires of the vacuum are now visible.
  5. Rowenta AC6221 Teardown: paso 6, imagen 1 de 2 Rowenta AC6221 Teardown: paso 6, imagen 2 de 2
    • The wires connect the charger light, switch,engine, and power wires.
    • The green box labels the engine.
    • The orange box labels one of the four batteries (4*1.2V)
  6. Rowenta AC6221 Teardown: paso 7, imagen 1 de 2 Rowenta AC6221 Teardown: paso 7, imagen 2 de 2
    • The top of the circuit board contains components including capacitors, resistors, wires, and a chip.
    • The bottom side shows the tracks that connect the components.
  7. Rowenta AC6221 Teardown: paso 8, imagen 1 de 2 Rowenta AC6221 Teardown: paso 8, imagen 2 de 2
    • Remove the screw securing the handle with a screwdriver.
    • Open the handle to see the inside using the flat screwdriver.
    • Warning: The handle is difficult to open
    • Warning: In this procedure, the handle was not opened to keep the vacuum intact.
  8. Rowenta AC6221 Teardown: paso 9, imagen 1 de 1
    • This is the pedestal that will be torn down.
  9. Rowenta AC6221 Teardown: paso 10, imagen 1 de 3 Rowenta AC6221 Teardown: paso 10, imagen 2 de 3 Rowenta AC6221 Teardown: paso 10, imagen 3 de 3
    • At the bottom of the pedestal, remove the 4 rubber pieces.
    • Note: This step provides access to 4 Philips screws.
    • Remove screws using a screwdriver.
  10. Rowenta AC6221 Teardown: paso 11, imagen 1 de 1
    • Lift the plastic piece carefully from the bottom of the pedestal.
  11. Rowenta AC6221 Teardown: paso 12, imagen 1 de 1
    • Inside the pedestal, the power cable separates into 2 wires. Each wire is connected to a conductive piece.
    • This completes the vacum cleaner teardown
Bob
Miembro Desde 04/17/10
760 Reputación
3 Guías creadas
Un comentario
This could use some discussion of how to replace the rechargeable batteries used in portable vacuum cleaners.
Wayne Seltzer - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 7
Ultimos 30 días: 17
Todo El Tiempo: 7,209
