Saltar al contenido principal
Qué necesitas
Este desmontaje no es una guía de reparación. Para reparar tu Panasonic EB TX320ASW, utiliza nuestros manuales de servicio .
  1. Panasonic EB TX320ASW Teardown, Panasonic EB TX320ASW Teardown: paso 1, imagen 1 de 2 Panasonic EB TX320ASW Teardown, Panasonic EB TX320ASW Teardown: paso 1, imagen 2 de 2
    • To remove the faceplate, pry the top of faceplate away from the phone. Follow snaps down, until faceplate is completely popped off.
  2. Panasonic EB TX320ASW Teardown: paso 2, imagen 1 de 1
    • To remove battery push clip in; battery will pop out.
  3. Panasonic EB TX320ASW Teardown: paso 3, imagen 1 de 1
    • Using a Star 3.0 bit, remove 4 screws in battery compartment.
  4. Panasonic EB TX320ASW Teardown: paso 4, imagen 1 de 2 Panasonic EB TX320ASW Teardown: paso 4, imagen 2 de 2
    • To separate front of phone from the back; start prying from bottom and work up the side. The phone should then pop apart.
  5. Panasonic EB TX320ASW Teardown: paso 5, imagen 1 de 1
    • To remove keypad, turn front of phone over and let keypad fall out. All keys are connected by one rubber section.
    • If a button had been ripped off your keypad, you can replace the entire rubber keypad at this step and reassemble phone.
  6. Panasonic EB TX320ASW Teardown: paso 6, imagen 1 de 3 Panasonic EB TX320ASW Teardown: paso 6, imagen 2 de 3 Panasonic EB TX320ASW Teardown: paso 6, imagen 3 de 3
    • To remove main-board from phone grab side of phone and pry upwards. Board should snap out.
  7. Panasonic EB TX320ASW Teardown: paso 7, imagen 1 de 1
    • To remove speaker cover, pull out silver plate.
  8. Panasonic EB TX320ASW Teardown: paso 8, imagen 1 de 2 Panasonic EB TX320ASW Teardown: paso 8, imagen 2 de 2
    • After silver plate is removed, power button sits freely. Speaker can be removed by pulling up on it.
    • If your speaker went out it can easily be replaced in this step with a new one, then reassemble phone after this step.
  9. Panasonic EB TX320ASW Teardown: paso 9, imagen 1 de 2 Panasonic EB TX320ASW Teardown: paso 9, imagen 2 de 2
    • To remove keyboard circuit press on the middle and slide down. The board will pop up allowing for removal.
  10. Panasonic EB TX320ASW Teardown: paso 10, imagen 1 de 3 Panasonic EB TX320ASW Teardown: paso 10, imagen 2 de 3 Panasonic EB TX320ASW Teardown: paso 10, imagen 3 de 3
    • To remove main-board from bracket, gently apply pressure to the four small clips. Board will pop out freely.
  11. Panasonic EB TX320ASW Teardown: paso 11, imagen 1 de 2 Panasonic EB TX320ASW Teardown: paso 11, imagen 2 de 2
    • To remove LCD screen pry back on highlighted clip and pull screen out. The screen will then pull up and out.
    • If the LCD screen went out, or was cracked somehow, replace with a new LCD screen and then reassemble phone from this step.
Andrew Foss
Miembro Desde 10/04/11
10 Reputación
1 Guía escrita
Equipo
UW Stout, Team 5-2, Zhou Fall 2011 Miembro de UW Stout, Team 5-2, Zhou Fall 2011
UWSTOUT-ZHOU-F11S5G2
2 Miembros
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 1
Todo El Tiempo: 3,445
