Saltar al contenido principal
Qué necesitas
Este desmontaje no es una guía de reparación. Para reparar tu Olympus Stylus 410, utiliza nuestros manuales de servicio .
  1. Olympus Stylus 410 Teardown, Slider: paso 1, imagen 1 de 1
    • Locate the 2 screws on the bottom of the slider.
    • Remove both screws with a #00 Phillips screwdriver.
  2. Olympus Stylus 410 Teardown: paso 2, imagen 1 de 1
    • Gently pull on the bottom of the slider until it comes off the lower track.
    • There is a little piece that connects the slider to the track. Be sure not to lose this as it is needed to put the slider back on.
  3. Olympus Stylus 410 Teardown: paso 3, imagen 1 de 1
    • Lift the slider up until it comes off the upper track.
  4. Olympus Stylus 410 Teardown: paso 4, imagen 1 de 1
    • The slider should now be free from the body of the camera.
  5. Olympus Stylus 410 Teardown, Outer Case: paso 5, imagen 1 de 3 Olympus Stylus 410 Teardown, Outer Case: paso 5, imagen 2 de 3 Olympus Stylus 410 Teardown, Outer Case: paso 5, imagen 3 de 3
    • Locate the 3 screws on the outer metal band and remove them with a #00 Phillips screwdriver.
  6. Olympus Stylus 410 Teardown: paso 6, imagen 1 de 2 Olympus Stylus 410 Teardown: paso 6, imagen 2 de 2
    • Use the spudger to peel off the outer metal band, starting from the bottom of the camera.
    • The metal band it attached to the camera with glue in addition to screws. Be careful not to bend the band when removing it from the camera.
  7. Olympus Stylus 410 Teardown: paso 7, imagen 1 de 2 Olympus Stylus 410 Teardown: paso 7, imagen 2 de 2
    • The shutter button can now be removed. It is not connected to the camera and can be lifted off.
  8. Olympus Stylus 410 Teardown: paso 8, imagen 1 de 2 Olympus Stylus 410 Teardown: paso 8, imagen 2 de 2
    • Remove the memory card.
    • Locate and remove the 2 screws using a #00 Phillips screwdriver.
  9. Olympus Stylus 410 Teardown: paso 9, imagen 1 de 3 Olympus Stylus 410 Teardown: paso 9, imagen 2 de 3 Olympus Stylus 410 Teardown: paso 9, imagen 3 de 3
    • Use a spudger around the edge of the case to loosen it.
    • Carefully wiggle the back case off. This may require a fair amount of force.
  10. Olympus Stylus 410 Teardown: paso 10, imagen 1 de 1
    • Locate the 3 internal screws holding on the front of the case. Remove them with a #00 Phillips screwdriver.
  11. Olympus Stylus 410 Teardown: paso 11, imagen 1 de 2 Olympus Stylus 410 Teardown: paso 11, imagen 2 de 2
    • While grasping the interior and the front case, gently pull until they start to come apart. Some light wiggling may be required.
    • Be careful not to completely pull the front case off because it will still be connected with wires.
  12. Olympus Stylus 410 Teardown, Flash: paso 12, imagen 1 de 2 Olympus Stylus 410 Teardown, Flash: paso 12, imagen 2 de 2
    • Locate the gray compartment covering the flash.
    • Position your flat head screw driver or small spudger underneath the tab that is keeping the gray cover on.
    • Gently lift the tab so the gray compartment becomes free.
  13. Olympus Stylus 410 Teardown: paso 13, imagen 1 de 3 Olympus Stylus 410 Teardown: paso 13, imagen 2 de 3 Olympus Stylus 410 Teardown: paso 13, imagen 3 de 3
    • Use the spudger around the perimeter of the gray compartment to detach it from the front case.
    • The gray compartment can now be removed from the flash unit.
    • The flash unit can now be removed, and a new one soldered back on.
  14. Olympus Stylus 410 Teardown, Battery Cover: paso 14, imagen 1 de 2 Olympus Stylus 410 Teardown, Battery Cover: paso 14, imagen 2 de 2
    • Open the battery cover and lift it up and off of back camera case.
  15. Olympus Stylus 410 Teardown: paso 15, imagen 1 de 3 Olympus Stylus 410 Teardown: paso 15, imagen 2 de 3 Olympus Stylus 410 Teardown: paso 15, imagen 3 de 3
    • Locate and unscrew the 2 screws with a #00 Phillips screwdriver.
    • Remove the black seal.
  16. Olympus Stylus 410 Teardown: paso 16, imagen 1 de 2 Olympus Stylus 410 Teardown: paso 16, imagen 2 de 2
    • Slide the metal piece off of the battery cover.
  17. Olympus Stylus 410 Teardown: paso 17, imagen 1 de 1
    • This is what the battery cover and back case look like completely disassembled.
  18. Olympus Stylus 410 Teardown, LCD Screen: paso 18, imagen 1 de 3 Olympus Stylus 410 Teardown, LCD Screen: paso 18, imagen 2 de 3 Olympus Stylus 410 Teardown, LCD Screen: paso 18, imagen 3 de 3
    • Remove the metal frame from the LCD screen using an opening tool.
  19. Olympus Stylus 410 Teardown: paso 19, imagen 1 de 3 Olympus Stylus 410 Teardown: paso 19, imagen 2 de 3 Olympus Stylus 410 Teardown: paso 19, imagen 3 de 3
    • Pry off the LCD screen from the top using an opening tool.
    • Do not pull the screen completely off because it will still be held on by two ribbon cables.
  20. Olympus Stylus 410 Teardown: paso 20, imagen 1 de 1
    • This is what the camera will look like now that the LCD screen is removed.
Rory Aronson
Miembro Desde 04/15/10
46 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 6-13, Maness Spring 2010 Miembro de Cal Poly, Team 6-13, Maness Spring 2010
CPSU-MANESS-S10S6G13
5 Miembros
17 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 8
Todo El Tiempo: 4,811
