Saltar al contenido principal
Qué necesitas
Este desmontaje no es una guía de reparación. Para reparar tu Nokia E61i, utiliza nuestros manuales de servicio .
  1. Nokia E61i Teardown, Battery: paso 1, imagen 1 de 2 Nokia E61i Teardown, Battery: paso 1, imagen 2 de 2
    • Remove the back cover to access the battery. Press the tab on the bottom of the cover.
    • Slide the back cover downwards off of the phone while pressing the tab down.
  2. Nokia E61i Teardown: paso 2, imagen 1 de 1
    • Locate the bottom-left corner of the phone where there is a spot to remove the battery.
  3. Nokia E61i Teardown: paso 3, imagen 1 de 1
    • Lift the battery out using your finger.
    • The E61i uses a Nokia BP-4L standard battery.
  4. Nokia E61i Teardown, Front Cover: paso 4, imagen 1 de 2 Nokia E61i Teardown, Front Cover: paso 4, imagen 2 de 2
    • Remove the four screws that secure the front cover to the rest of the phone using a T7 screwdriver.
  5. Nokia E61i Teardown: paso 5, imagen 1 de 1
    • Remove the cover by pulling it up and off.
  6. Nokia E61i Teardown, Keyboard: paso 6, imagen 1 de 1
    • Once the front cover has been removed, there is nothing holding the keyboard to the rest of the phone. Simply remove the keyboard from the cover by lifting the keyboard from its interior side.
  7. Nokia E61i Teardown, Display: paso 7, imagen 1 de 2 Nokia E61i Teardown, Display: paso 7, imagen 2 de 2
    • Take off the casing and keyboard.
    • Remove the screws while holding the screen in place using a Torx T6 screwdriver.
    • Remove the single screw while holding the screen in place using a Torx T5 screwdriver.
    • Lift the ribbon off of the contact with the motherboard.
    • Firmly press the contacts into place to connect the ribbon and the motherboard when reassembling.
  8. Nokia E61i Teardown: paso 8, imagen 1 de 2 Nokia E61i Teardown: paso 8, imagen 2 de 2
    • Gently pull the screen off of the phone.
    • Be sure not to rip the sticker that connects the display and the motherboard.
    • Pull the silver case off to completely free the cracked or damaged screen.
  9. Nokia E61i Teardown, Speaker: paso 9, imagen 1 de 2 Nokia E61i Teardown, Speaker: paso 9, imagen 2 de 2
    • Remove the speaker by pulling it off of the display frame.
    • The speaker is connected to the display frame by a ring of adhesive foam (visible in second picture). By removing the speaker, this foam is torn. However, the speaker sticks quite well to the frame without reapplication of any adhesive.
  10. Nokia E61i Teardown, Motherboard: paso 10, imagen 1 de 3 Nokia E61i Teardown, Motherboard: paso 10, imagen 2 de 3 Nokia E61i Teardown, Motherboard: paso 10, imagen 3 de 3
    • Pull the green motherboard from the back casing.
  11. Nokia E61i Teardown, Antenna: paso 11, imagen 1 de 2 Nokia E61i Teardown, Antenna: paso 11, imagen 2 de 2
    • After the logic board has been removed, there is nothing else securing the antenna to the back cover. Simply remove the antenna by pushing outward from the interior side.
  12. Nokia E61i Teardown, Volume Control Buttons: paso 12, imagen 1 de 1
    • The volume control buttons are secured to the frame only by their fit around a small piece of the plastic. Using a small flat-head screwdriver or other flat object, lift the ribbon over this piece of the cover.
  13. Nokia E61i Teardown: paso 13, imagen 1 de 1
    • Next, remove the volume control buttons from the cover by pushing or pulling them out away from the interior of the cover.
  14. Nokia E61i Teardown, Connector Housing: paso 14, imagen 1 de 1
    • Remove the connector housing by pushing and sliding it off the back panel.
    • Be very careful not to lose the small loose spring from behind the button or the small button itself.
  15. Nokia E61i Teardown, Disassembling Nokia E61i Microphone: paso 15, imagen 1 de 1
    • After the Connector Housing has been removed, there is nothing else holding the Microphone in place. Simply remove if from the housing by pulling up.
  16. Nokia E61i Teardown, Headset Jack: paso 16, imagen 1 de 1
    • Remove the headset jack from the housing by pulling it up.
Equipo
Cal Poly, Team 9-63, Walters Spring 2011 Miembro de Cal Poly, Team 9-63, Walters Spring 2011
CPSU-WALTERS-S11S9G63
5 Miembros
12 Guías creadas
Un comentario
hai sir.. can you help me to suggestion for campatible camera module (from another nokia series) for Nokia E61i ?
Ricky Rekintan Sumsago - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 2
Todo El Tiempo: 7,534
