Saltar al contenido principal
Qué necesitas
Este desmontaje no es una guía de reparación. Para reparar tu Nokia 6108, utiliza nuestros manuales de servicio .
  1. Nokia 6108 Teardown, Nokia 6108 Teardown: paso 1, imagen 1 de 1
    • Hello,I'm going to open my phone for some fun.
    • Be careful not to drop any screws or parts when you're opening your phone.This may render your phone not usuable.Open your phone at your own risk.
  2. Nokia 6108 Teardown: paso 2, imagen 1 de 2 Nokia 6108 Teardown: paso 2, imagen 2 de 2
    • Remove the following parts.
    • Battery cover
    • Battery
    • SIM card
    • Remove two trox screws marked in figure 2.
  3. Nokia 6108 Teardown: paso 3, imagen 1 de 2 Nokia 6108 Teardown: paso 3, imagen 2 de 2
    • Remove the front panel by pulling it or using an
    • I don't have a opening tool.So I used a flathead screw driver instead.
    • Be careful not the damage the number pad connector(highlighted in red).If you break it.You'll have to replace the entre front panel.
  4. Nokia 6108 Teardown: paso 4, imagen 1 de 2 Nokia 6108 Teardown: paso 4, imagen 2 de 2
    • Remove 5 trox screws that are holding the screen and the touch pad.
  5. Nokia 6108 Teardown: paso 5, imagen 1 de 2 Nokia 6108 Teardown: paso 5, imagen 2 de 2
    • After removing the touch pad and the screen.You can remove the logic board from the case.
    • The board seem don't want to leave its cozy home.
  6. Nokia 6108 Teardown: paso 6, imagen 1 de 1
    • Let's start removing the parts under the logic board.
    • Parts need to be removed.
    • A motor
    • Charger connector
    • A speaker
  7. Nokia 6108 Teardown: paso 7, imagen 1 de 1
    • Removing the EMI shield.Pry around the edge of the shield to remove it.
  8. Nokia 6108 Teardown: paso 8, imagen 1 de 2 Nokia 6108 Teardown: paso 8, imagen 2 de 2
    • Nothing under the EMI shield.
    • I think we should stop here right now.There are pictures for all parts.
Honam1021
Miembro Desde 02/19/11
349 Reputación
1 Guía escrita
Un comentario
i have same phone but it's keypad button's are not working.... can u help me that
Rohit Yadav - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 17
Todo El Tiempo: 4,729
