Saltar al contenido principal
Qué necesitas
Este desmontaje no es una guía de reparación. Para reparar tu Nikon Coolpix 3500, utiliza nuestros manuales de servicio .
  1. Nikon Coolpix 3500 Teardown, Nikon Coolpix 3500 Teardown: paso 1, imagen 1 de 1
    • Remove the battery cover.
    • Remove the battery.
  2. Nikon Coolpix 3500 Teardown: paso 2, imagen 1 de 1
    • Remove two 4.5 mm screws next to the battery slot.
    • Remove one 3 mm screw above the CF memory card slot.
    • Remove one 4.5 mm screw next to the CF memory card slot.
  3. Nikon Coolpix 3500 Teardown: paso 3, imagen 1 de 1
    • Remove two 4.5 mm screws from inside the battery slot.
  4. Nikon Coolpix 3500 Teardown: paso 4, imagen 1 de 1
    • Remove two 5 mm screws from the opposite end of the battery slot.
  5. Nikon Coolpix 3500 Teardown: paso 5, imagen 1 de 1
    • Remove the plastic cap and the 5 mm screw underneath.
  6. Nikon Coolpix 3500 Teardown: paso 6, imagen 1 de 1
    • Remove the five 3.5 mm screws from the bottom of the camera.
    • Gently pry off the grey faceplate.
    • Do not pull hard; there are two wires connecting the faceplate to the motherboard.
  7. Nikon Coolpix 3500 Teardown: paso 7, imagen 1 de 3 Nikon Coolpix 3500 Teardown: paso 7, imagen 2 de 3 Nikon Coolpix 3500 Teardown: paso 7, imagen 3 de 3
    • Use a spudger to disconnect the white-capped wire at the bottom of the camera.
    • Use a spudger to disconnect the orange-capped wire at the bottom of the camera and set the faceplate aside.
  8. Nikon Coolpix 3500 Teardown: paso 8, imagen 1 de 1
    • Disconnect the grey-capped wires from the motherboard.
    • Disconnect the blue wire attached to the green chip from the center of the motherboard.
  9. Nikon Coolpix 3500 Teardown: paso 9, imagen 1 de 2 Nikon Coolpix 3500 Teardown: paso 9, imagen 2 de 2
    • Remove the 3.5 mm screw from the motherboard next to the rotating lens.
    • Flip the motherboard and lens over to access the three wires on the back that connect to the LED screen.
  10. Nikon Coolpix 3500 Teardown: paso 10, imagen 1 de 2 Nikon Coolpix 3500 Teardown: paso 10, imagen 2 de 2
    • Disconnect the blue wire connecting the motherboard to the LED screen.
    • Disconnect the orange wire using a spudger while pushing out horizontally.
    • Disconnect the red capped wire from the motherboard.
    • Lift the motherboard and lens (still connected) out of the back case.
  11. Nikon Coolpix 3500 Teardown: paso 11, imagen 1 de 1
    • Lift up on the black covering and remove the orange wire connecting the lens to the motherboard.
  12. Nikon Coolpix 3500 Teardown: paso 12, imagen 1 de 1
    • Remove the 2.5 mm screw next to the red capped wire.
    • Remove the two 3.4 mm screws on the back of the directional buttons.
    • Remove the two 4.4 mm screws in the metal plate across from the orange wire.
  13. Nikon Coolpix 3500 Teardown: paso 13, imagen 1 de 2 Nikon Coolpix 3500 Teardown: paso 13, imagen 2 de 2
    • Gently lift the LED screen out of the remaining casing and set it aside.
    • Be careful not to let the rubber backing of the buttons fall out of place.
Equipo
Cal Poly, Team 30-38, Garner Spring 2010 Miembro de Cal Poly, Team 30-38, Garner Spring 2010
CPSU-GARNER-S10S30G38
5 Miembros
11 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 4
Todo El Tiempo: 7,759
