Herramientas Destacadas en este Teardown
Este desmontaje no es una guía de reparación. Para reparar tu Motorola California Mobile Phone, utiliza nuestros manuales de servicio .
Remove the battery by sliding it down the rails to which it is connected.
  • Remove the battery by sliding it down the rails to which it is connected.
Agregar Comentario
Find a flat head or Phillips head screwdriver.
  • Find a flat head or Phillips head screwdriver.
  • Insert the screwdriver into the holes in the plastic rod connecting the key pad guard to the rear casing.
  • Use the screwdriver to push the rods towards each other until they click out of their locked position.
  • Note: This may require a large amount of force.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Slide off the antenna guard and locate the four clips on the exterior of the rear casing.
  • Slide off the antenna guard and locate the four clips on the exterior of the rear casing.
  • Simultaneously push the clips outward while lifting the rear casing and keyguard away from the front casing.
  • Remove the key guard from the rear casing by taking it out of its position.
Agregar Comentario
Locate and unplug the black component of the antenna from the motherboard.
  • Locate and unplug the black component of the antenna from the motherboard.
  • Under the black component should be a blue component. Unscrew this component in order to free the antenna.
Agregar Comentario
Slide the antenna out of the green tubing and slide the green tubing out of it's corresponding hole on the motherboard.
  • Slide the antenna out of the green tubing and slide the green tubing out of it's corresponding hole on the motherboard.
Agregar Comentario
Lift the motherboard out of its location in the front casing.
  • Lift the motherboard out of its location in the front casing.
  • Do this slowly and gently so that none of the motherboard's components are damaged.
Agregar Comentario
Andrew Lam
Miembro Desde 17/04/12
28 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 9-46, Regan Spring 2012 Miembro de Cal Poly, Team 9-46, Regan Spring 2012
CPSU-REGAN-S12S9G46
5 Miembros
8 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 3
Últimos 30 Días: 8
Todo El Tiempo: 7,000
