Herramientas Destacadas en este Teardown
Introducción
A mobile robot developed in the 80s by Tomy and sold by Radioshack in the United States.
More videos and information can be found at the I Heart Robotics blog
This guide shows a tear down of the main arm.
Este desmontaje no es una guía de reparación. Para reparar tu Mobile Armatron, utiliza nuestros manuales de servicio .
Open up the remote control. Open up the remote control. Open up the remote control.
  • Open up the remote control.
Agregar Comentario
Remove the screw as indicated. Remove the screw as indicated.
  • Remove the screw as indicated.
Agregar Comentario
If someone spilled soda or apple juice over the controller it may be helpful to clean the board using contact cleaner. If someone spilled soda or apple juice over the controller it may be helpful to clean the board using contact cleaner.
  • If someone spilled soda or apple juice over the controller it may be helpful to clean the board using contact cleaner.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Remove screws where indicated.
  • Remove screws where indicated.
Agregar Comentario
Gripper components can be removed for further disassembly. Gripper components can be removed for further disassembly. Gripper components can be removed for further disassembly.
  • Gripper components can be removed for further disassembly.
Agregar Comentario
Use the knife to peel off stickers that conceal the screw holes. Use the knife to peel off stickers that conceal the screw holes. Use the knife to peel off stickers that conceal the screw holes.
  • Use the knife to peel off stickers that conceal the screw holes.
Agregar Comentario
More screws can be removed to check the condition of gear teeth. Admire the mechanical design. Admire the mechanical design.
  • More screws can be removed to check the condition of gear teeth.
  • Admire the mechanical design.
Agregar Comentario
I Heart Robotics
Miembro Desde 09/11/09
210 Reputación
3 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 18
Todo El Tiempo: 10,077
