Introducción
We disassembled this computer on October 15, 2008.
Qué necesitas
Apple boasts that, "The new MacBook packaging is 41 percent smaller than the previous generation" and is made from recycled material.
Smaller packaging, they say, means fewer planes to transport the same number of products.
Follow our updates on twitter.
It looks like a MacBook Air from the top, but it's about 25% thicker than the thickest part of the Air, and almost 6 times thicker than the thinnest part.
To be fair, though, it's about 12 percent thinner than its predecessor (0.95 in vs. 1.08 in) and 10 percent lighter (4.5 pounds vs. 5 pounds).
The hard drive is on the left, and the battery is on the right.
The new MacBook uses the same hard drives as previous MacBook models.
Shameless plug: If you're not ready for a new machine, you can upgrade the hard drive in any Apple laptop. We have free guides for most models that make hard drive replacements easy.
The top of the logic board. (Click on the image for a larger version.)
Part numbers found thus far:
Penryn Intel Core 2 Duo Mobile Processor P8600 5827B394 SLB4N AV80577P8600 2.40/3M/1066
Cypress USB Controller CY7C638 33LFXC 0825 KOR 633013
K0328 8F1 50C8 & K0305 8F5 5022
F2117LP 20H V AF03370 0824JPN
REALTEK RTL8251CA 86085S2 G831 TAIWAN
Compare this to the previous MacBook logic board.
The bottom of the logic board.
Cypress PSoC Mixed-Signal Array CY8C24794-24L FXI 0831 A 04 KOR CYP 637569
Realtek HD Audio Codec ALC885 87J24A1 G83283
TDK 6T213HF 0838 d
ISL95O4 BHRZ H0832BB49
APP001 928 3T 0829A
SN 802043 TI 87K JR7C G4
7 comentarios
While disassembling my MacBook 2008-11 model as seen in these pictures, I was careful to lay out and label each part to reassemble after attempting to repair from water damage. When I lifted the hard drive a small black rectangular bracket about 1/2 wide with a small square on the back and an extruding piece against the black hollow square tha appears would go over a screw hole; dropped to the floor. It has part number ZYI-4 as best I can make out. Does anyone know where this goes? I cannot figure it out. Thanks!!!!
Hi Label beetween keyboard a lil bit part i dont see in my macbook. This part is ? Because my macbook dont turn on.
