Teardown
Taking apart the phone
Este desmontaje no es una guía de reparación. Para reparar tu LG TP 1100, utiliza nuestros manuales de servicio .
Unscrew and remove antenna from socket
Turn the phone over
Pull up on the tab at the top
Remove the Battery
Unscrew the four screws behind the battery
Pull off and remove the back cover
Do not separate the covers
Do not rip the tape connecting the two covers
Remove back cover
Pry the circuit board from front cover
Do not let number pad fall out
Now remove the number pad and navigation keys
Pry out microphone with opening tool
Slide opening tool into crevasse and pry open top cover
Do so on both sides
Do not completely remove cover
Pry out speaker with heavy-duty spudger
Caution: Do not disconnect the wires connecting the speaker, they are very fragile
con 5 otros colaboradores
Miembro Desde 04/10/10
1 Reputación
3 Guías creadas
Insignias: 3
CPSU-AMIDO-S10S27G91
5 Miembros
11 Guías creadas
Elige el tamaño y copia el siguiente código para insertar esta guía como un pequeño widget en tu sitio web o foro.
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 14
Todo El Tiempo: 5,086
