Introducción
This will provide information on dissembling the phone to allow for repairs.
Este desmontaje no es una guía de reparación. Para reparar tu Kyocera Oystr, utiliza nuestros manuales de servicio .
Make sure the phone is turned off before disassembly. Lift the bottom of the phone's back cover upwards, revealing the phone's battery housing. Remove the battery from the casing. This is simply a precaution.
  • Make sure the phone is turned off before disassembly.
  • Lift the bottom of the phone's back cover upwards, revealing the phone's battery housing.
  • Remove the battery from the casing. This is simply a precaution.
  • Turn the phone over so that the front side is facing you. Flip open the device in preparation for the next step.
Agregar Comentario
Peel the Virgin Mobile sticker from the phone's screen, revealing two screws beneath it. Using the Tri-Wing Y0 screwdriver, remove the two screws from the screen. Using the Tri-Wing Y0 screwdriver, remove the two screws from the screen.
  • Peel the Virgin Mobile sticker from the phone's screen, revealing two screws beneath it.
  • Using the Tri-Wing Y0 screwdriver, remove the two screws from the screen.
Agregar Comentario
Lift the plastic cover of the phone screen upwards by prying around the perimeter of the screen with a plastic opening tool. After lifting the plastic cover from the screen, remove the two screws from the metal cover holding the screen in place. After lifting the plastic cover from the screen, remove the two screws from the metal cover holding the screen in place.
  • Lift the plastic cover of the phone screen upwards by prying around the perimeter of the screen with a plastic opening tool.
  • After lifting the plastic cover from the screen, remove the two screws from the metal cover holding the screen in place.
Agregar Comentario
Remove metal cover by lifting up and away from the device.
  • Remove metal cover by lifting up and away from the device.
Agregar Comentario
Remove the phone's speakers by using the plastic opening tool to pry up and away from the device. These speakers will dangle by the wires attached to the board. Use your fingernail to detach the ribbon connecting the board to the screen. Remove the damaged screen from the device.
  • Remove the phone's speakers by using the plastic opening tool to pry up and away from the device. These speakers will dangle by the wires attached to the board.
  • Use your fingernail to detach the ribbon connecting the board to the screen.
  • Remove the damaged screen from the device.
Agregar Comentario
Follow steps in reverse order to replace Kyocera Oystr’s screen.
  • Follow steps in reverse order to replace Kyocera Oystr’s screen.
Agregar Comentario
David
Miembro Desde 04/10/11
24 Reputación
2 Guías creadas
Equipo
UW Stout, Team 5-7, Zhou Fall 2011 Miembro de UW Stout, Team 5-7, Zhou Fall 2011
UWSTOUT-ZHOU-F11S5G7
2 Miembros
2 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 2
Últimos 30 Días: 5
Todo El Tiempo: 3,640
