Herramientas Destacadas en este Teardown
Introducción
The main thing that usually breaks on a jump starter is the battery. These units usually contain a lead acid battery with a finite lifespan. It is possible and simple to replace but usually not financially worth doing. If the unit does not hold a charge but functions while it is plugged in then it is most likely a faulty battery.
Este desmontaje no es una guía de reparación. Para reparar tu Jump Starter Power Station, utiliza nuestros manuales de servicio .
Power Station Jump Starter Model PS1100 The bad battery could be replaced to restore it to full functionality.
  • Power Station Jump Starter
  • Model PS1100
  • The bad battery could be replaced to restore it to full functionality.
Agregar Comentario
Opening it up reveals the Lead battery, AC/DC converter, 12V DC input, switch, back of circuit board, back of light. Additional bells and whistles are sometimes added (lights, switches, compressors, power jacks, etc.)  Some have AC power jacks which require a DC/AC converter which is more expensive than an AD/DC converter. Additional bells and whistles are sometimes added (lights, switches, compressors, power jacks, etc.)  Some have AC power jacks which require a DC/AC converter which is more expensive than an AD/DC converter.
  • Opening it up reveals the Lead battery, AC/DC converter, 12V DC input, switch, back of circuit board, back of light.
    • Additional bells and whistles are sometimes added (lights, switches, compressors, power jacks, etc.) Some have AC power jacks which require a DC/AC converter which is more expensive than an AD/DC converter.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
The battery to the left is the culprit of the dead power supply.  A jump starter is nothing more than a small car battery with some wires. Any 12V battery with the same dimensions should work as a replacement
  • The battery to the left is the culprit of the dead power supply. A jump starter is nothing more than a small car battery with some wires.
  • Any 12V battery with the same dimensions should work as a replacement
    • This is a Lead 12V 17AmpHours battery made by Pilot battery Co. Ltd.
    • Model PL17-12
Agregar Comentario
Both power inputs.  AC/DC converter and DC 12V input. The designers of this jump starter simply purchased an aftermarket AC/DC adapter and built it in.
  • Both power inputs. AC/DC converter and DC 12V input.
  • The designers of this jump starter simply purchased an aftermarket AC/DC adapter and built it in.
    • The adapter has an input of 120V (typical outlet voltage) and an output of 15V (perfect for charging a 12V battery).
  • Left - DC Power Jack, Right - Thermal Relay for safety and protection
Agregar Comentario
Circuit board with your typical LEDs, Resistors, Transistors (black half circles), IC chips (long black), Capacitors (disks and cyliders), buttons (right middle) Power Rectifier (left middle square), Diodes (small black, bar on one side), Piezo Speaker (large and round, bottom) Light with 5 LED's Big Switch to handle 12V
  • Circuit board with your typical LEDs, Resistors, Transistors (black half circles), IC chips (long black), Capacitors (disks and cyliders), buttons (right middle) Power Rectifier (left middle square), Diodes (small black, bar on one side), Piezo Speaker (large and round, bottom)
  • Light with 5 LED's
  • Big Switch to handle 12V
Agregar Comentario
The back module is the compressor.  It will still function normally by application of a 12v power supply. I did not disassemble the compressor.  I will bolt a plexiglass cover over the top and solder a 12v car adapter to run it as an emergency compressor
  • The back module is the compressor. It will still function normally by application of a 12v power supply.
    • I did not disassemble the compressor. I will bolt a plexiglass cover over the top and solder a 12v car adapter to run it as an emergency compressor
  • I have a walk through on recycling the compressor on instructables.com
Agregar Comentario
Brent Olsen
Miembro Desde 26/07/11
381 Reputación
1 Guía escrita
where can i find more information on the circuit? plan to add a switch to my jumpstarter to either charge the internal battery or an external battery...
would that 700mA handle a 65Ah battery if i simply attach a device like that to that slightly bigger battery?
gcb - Contestar
i like this article,thanks for sharing,i bought one before and it was good,i think we all need car jump starter,i would like to recommend one oem jump starter factory,http://www.mairpower.com
MAIR POWER - Contestar
I have one of these that the ac adapter has come loose from the main board. is there a possibility that you could post a photo of exactly where the adapter solders onto the main board?
Phillip Duke - Contestar
can I use a 12V 18Amp
pjfz80 - Contestar
To charge the battery? The back of the unit will say what the "input" should be.
Brent Olsen -
helpful article any chance on getting the dimension of the battery I do not see PL17-12 but many like it. the dimension would be helpful
Edward Ginsberg - Contestar
Thanks for the information, I was able to purchase a 6FM-18 battery that was a perfect fit and it is all up and running, great help from your post.
What is the peak amp output this will start a vehicle with is it 1100 peak amps? as in the model number
My compressor will not come on. It can on one time then makes a noise but does not put out compressor air, any ideas?
trdnface - Contestar
Thanks for this tutorial. it was very helpful.
iweld Alexander - Contestar
was using my unit as an air compressor. the unit shut off in just a few minutes and now nothing will come on. no led display
Ronnie Laws - Contestar
The air compessor hose nozzle which connects to the tire valve stem broke off in my PS1100. Any idea where I can find a replacement part?
Mike Fatah - Contestar
I am 99% sure that you will never find that part. any of these components aren't really meant to be replaced. Things like the battery or the ac-dc converter you can find because they just used off-the-shelf parts. You could probably find that size hose but you would have to find a way to seal/crimp it onto the air nozzle on the other end.
Brent Olsen - Contestar
Truth is that all these jump starter/compressor combos are Chinese imported junk. You can extend it’s life if you purchase it new from store and charge that battery 72 hours before ever touching anything else on the unit. Never set or store the unit on bare concrete and if you can avoid it never use the compressor once. If you must then leave it on a maximum of 2 mins a use and full recharge after each use. These units are actually pretty well made and very durable. No fuse will save a defective one of these units because no fuse in it. Never purchase any item needing these type of lead sealed batteries. They’re all defective and just being sold in every possible item they can use them in because theyre dirt cheap and lead. They already have much cheaper and far more reliable versions of these batteries and wont update because they have a cash income source with the defects that just keeps giving and giving. Razor Scooter, best built scooter youll find, rechargeable sealed batteries make them junk.
mark buller - Contestar
Its the sealed batteries. Purchase no product that uses these. Defective in Razor Scooters and all forms of medical scooters, all electric toy cars and the electric shopping carts in stores..Already have lithium batteries that can remedy all of the above..why havent they? Why isnt it an option at purchase? The jump starters cant be lithium until the car batteries are. Why arent they both? Called robbing the consumer. Dont purchase any item with lead sealed rechargeable!!!
My speedway start to finish 4 to 1 power station, doesn't charge anymore. What must I do to get it charged? Is there anyone I can send it to to fix it?
beltonmandy - Contestar
My Speedway start to finish 4 in 1 power station doesn't charge anymore. Is anyone I can send it to, to get fix?
Nice tutorial can you do one for the die hard heavy duty jumper I have reviewed it here https://carjumpstarterreview.com
Marwat Qureshi - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 72
Últimos 7 Días: 347
Últimos 30 Días: 1,609
Todo El Tiempo: 85,652
