Saltar al contenido principal
Qué necesitas
Este desmontaje no es una guía de reparación. Para reparar tu Hyundai H-150, utiliza nuestros manuales de servicio .
  1. Hyundai H-150 Teardown, Hyundai H-150 Teardown: paso 1, imagen 1 de 3 Hyundai H-150 Teardown, Hyundai H-150 Teardown: paso 1, imagen 2 de 3 Hyundai H-150 Teardown, Hyundai H-150 Teardown: paso 1, imagen 3 de 3
    • We'll start with a preview of the phone. Front, back and side view are shown here.
  2. Hyundai H-150 Teardown: paso 2, imagen 1 de 3 Hyundai H-150 Teardown: paso 2, imagen 2 de 3 Hyundai H-150 Teardown: paso 2, imagen 3 de 3
    • The battery is removed easily. Just pull down the part from the back and the battery goes out.
  3. Hyundai H-150 Teardown: paso 3, imagen 1 de 3 Hyundai H-150 Teardown: paso 3, imagen 2 de 3 Hyundai H-150 Teardown: paso 3, imagen 3 de 3
    • After the battery is out, we're presented with a plastic cover with all the phone's information (Model No., Serial No etc)
    • Notice the 4 Philips screw-heads in each of the four corners. Those need to go off.
    • After unscrewing, you might notice that the cover doesn't easily go off. Four clips are holding the back cover onto the front cover.
    • Use a Spudger and unclip the sides of the cover. It shouldn't put up much resistance
  4. Hyundai H-150 Teardown: paso 4, imagen 1 de 3 Hyundai H-150 Teardown: paso 4, imagen 2 de 3 Hyundai H-150 Teardown: paso 4, imagen 3 de 3
    • Once the back cover is off, one can see the motherboard and a strange metal part on the top of the phone. This serves as an antenna booster, but also to protect the board.
  5. Hyundai H-150 Teardown: paso 5, imagen 1 de 3 Hyundai H-150 Teardown: paso 5, imagen 2 de 3 Hyundai H-150 Teardown: paso 5, imagen 3 de 3
    • See that hole in the shield? That Has a screw in it. And yes, it needs to leave.
    • After removing the screw from the shield, it can be lifted from the board easily, revealing another board beneath it.
  6. Hyundai H-150 Teardown: paso 6, imagen 1 de 3 Hyundai H-150 Teardown: paso 6, imagen 2 de 3 Hyundai H-150 Teardown: paso 6, imagen 3 de 3
    • It seems that this secondary board is held onto the main board by a board connector.
    • Pull the board gently and you'll notice it comes out rather fast.
  7. Hyundai H-150 Teardown: paso 7, imagen 1 de 3 Hyundai H-150 Teardown: paso 7, imagen 2 de 3 Hyundai H-150 Teardown: paso 7, imagen 3 de 3
    • By this stage, the board simply comes out of the front body, exposing the keyboard and its associated membrane.
    • On the board we encounter the ringer(upper left), the headphone/handsfree input(under the ringer) and the LCD (which is sadly sticked on the board, as is the keypad membrane)
    • On the case we encounter the microphone (lowest part of the phone case), the loudspeaker (the highest part of the phone case)
  8. Hyundai H-150 Teardown: paso 8, imagen 1 de 2 Hyundai H-150 Teardown: paso 8, imagen 2 de 2
    • That concludes the teardown for now.
Nicolay
Miembro Desde 04/08/13
371 Reputación
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 819
