Saltar al contenido principal
Qué necesitas
Este desmontaje no es una guía de reparación. Para reparar tu Humax IRHD 5000C, utiliza nuestros manuales de servicio .
  1. Humax IRHD 5000C Teardown, open up case: paso 1, imagen 1 de 2 Humax IRHD 5000C Teardown, open up case: paso 1, imagen 2 de 2
    • Unscrew the screws on the outside.
    • Slide the top cover a bit to the back, and lift it from the enclosure.
  2. Humax IRHD 5000C Teardown, remove power supply: paso 2, imagen 1 de 2 Humax IRHD 5000C Teardown, remove power supply: paso 2, imagen 2 de 2
    • Remove the various pieces holding in the power supply.
    • Remove power cable (already cut of in the photo).
    • Unscrew screws.
    • Disconnect mainboard cables.
    • Remove the power supply from the enclosure.
  3. Humax IRHD 5000C Teardown, remove front: paso 3, imagen 1 de 2 Humax IRHD 5000C Teardown, remove front: paso 3, imagen 2 de 2
    • Disconnect the cables connecting the mainboard to the front panel.
    • With a flathead screwdriver, unclip the 2 topside clips, and 3 clips on the bottom of the enclosure, and the front will detach.
  4. Humax IRHD 5000C Teardown, disassemble front: paso 4, imagen 1 de 3 Humax IRHD 5000C Teardown, disassemble front: paso 4, imagen 2 de 3 Humax IRHD 5000C Teardown, disassemble front: paso 4, imagen 3 de 3
    • Unclip the 4 clips from left to right, and remove the panel.
    • With the pliers, clamp the white connector and push it through.
  5. Humax IRHD 5000C Teardown, remove mainboard: paso 5, imagen 1 de 2 Humax IRHD 5000C Teardown, remove mainboard: paso 5, imagen 2 de 2
    • Unscrew the screws and remove the mainboard from the case.
knipwim
Miembro Desde 09/01/18
8,516 Reputación
30 Guías creadas
2 comentarios
What are those unsoldered pad connectors for? A hard drive?
Jessica Parnelli Fawkes - Contestar
Don’t know, could be a SCSI drive, there are 68 pins. I included a detail picture in the last step.
knipwim -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 7
Todo El Tiempo: 1,421
