Introducción
This is a fun look into dismantling a G&G CM16 GBB Raider Long Airsoft and should not be used as a guide.
Este desmontaje no es una guía de reparación. Para reparar tu GG Combat Machine GBB Raider Long, utiliza nuestros manuales de servicio .
Push out the front receiver-takedown pin, but do not completely remove. Slide the upper receiver-takedown pin forward, separating it from the lower piece. Gently pulling back on the charging handle can make this easier. Slide the upper receiver-takedown pin forward, separating it from the lower piece. Gently pulling back on the charging handle can make this easier.
  • Push out the front receiver-takedown pin, but do not completely remove.
  • Slide the upper receiver-takedown pin forward, separating it from the lower piece. Gently pulling back on the charging handle can make this easier.
Agregar Comentario
Once the two receiver-takedown pin have been separated, unhook the charging handle from the spring. Punch out the rear takedown pin from the lower receiver. These pieces should fully separate in the rear piece, but will not fully separate in the front piece. Lift the bolt assembly from the lower receiver.
  • Once the two receiver-takedown pin have been separated, unhook the charging handle from the spring.
  • Punch out the rear takedown pin from the lower receiver. These pieces should fully separate in the rear piece, but will not fully separate in the front piece.
  • Lift the bolt assembly from the lower receiver.
Agregar Comentario
Remove the clip that secures the barrel to the hop-up unit. Pull out the barrel and remove the hop-up bucking.
  • Remove the clip that secures the barrel to the hop-up unit.
  • Pull out the barrel and remove the hop-up bucking.
Agregar Comentario
Using a Phillips screwdriver, remove the screw securing the  pistol grip to the gun. Remove the pistol grip from the gun. Optional: remove the screw securing the buffer tube to the gun, then remove the buffer tube/stock assembly. A round nut should fall out of the buffer tube after the assembly is removed (shown in third picture).
  • Using a Phillips screwdriver, remove the screw securing the pistol grip to the gun.
  • Remove the pistol grip from the gun.
  • Optional: remove the screw securing the buffer tube to the gun, then remove the buffer tube/stock assembly. A round nut should fall out of the buffer tube after the assembly is removed (shown in third picture).
Agregar Comentario
Remove the screw from the magazine catch. After the screw is removed, the magazine catch assembly should come apart in four pieces (screw, button, spring, arm). Punch out the small receiver pin from the right side of the gun (see picture). It is important that you do not try to do this from the right side. One end of the pin is textured to prevent it from coming loose, and pushing this end through the receiver may cause minor damage. Set the selector to "semi" and remove the fire control assembly from the lower receiver.
  • Remove the screw from the magazine catch. After the screw is removed, the magazine catch assembly should come apart in four pieces (screw, button, spring, arm).
  • Punch out the small receiver pin from the right side of the gun (see picture). It is important that you do not try to do this from the right side. One end of the pin is textured to prevent it from coming loose, and pushing this end through the receiver may cause minor damage.
  • Set the selector to "semi" and remove the fire control assembly from the lower receiver.
Agregar Comentario
Push the selector drum (as shown in the second picture) and unhook the leg of the spring holding it in place. Once the spring is unhooked, remove the selector drum. Once the spring is unhooked, remove the selector drum.
  • Push the selector drum (as shown in the second picture) and unhook the leg of the spring holding it in place.
  • Once the spring is unhooked, remove the selector drum.
Agregar Comentario
Pull the brass trigger pin out from the left side; the disconnector and spring will proceed to fall out. Set the trigger aside to use later.
  • Pull the brass trigger pin out from the left side; the disconnector and spring will proceed to fall out.
  • Set the trigger aside to use later.
Agregar Comentario
Push out the hammer/striker pin. Remove the hammer. Remove the hammer.
  • Push out the hammer/striker pin.
  • Remove the hammer.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Remove the trigger and striker from the gun. The striker will be attached to the trigger with a small spring. Note the positioning of the trigger and the spring. Push out the auto sear pin. The auto sear assembly should proceed to come out in three parts: sear, spring, and brass spacer. Push out the auto sear pin. The auto sear assembly should proceed to come out in three parts: sear, spring, and brass spacer.
  • Remove the trigger and striker from the gun. The striker will be attached to the trigger with a small spring. Note the positioning of the trigger and the spring.
  • Push out the auto sear pin. The auto sear assembly should proceed to come out in three parts: sear, spring, and brass spacer.
Agregar Comentario
Unhook the charging-handle spring from the top of the bolt assembly. Remove the five screws on the bolt assembly.
  • Unhook the charging-handle spring from the top of the bolt assembly.
  • Remove the five screws on the bolt assembly.
Agregar Comentario
Pull the bolt backwards, and separate it from the plastic shell. Remove the bolt, recoil spring, and nozzle assembly from the shell. Remove the bolt, recoil spring, and nozzle assembly from the shell.
  • Pull the bolt backwards, and separate it from the plastic shell.
  • Remove the bolt, recoil spring, and nozzle assembly from the shell.
Agregar Comentario
Insert the bolt and nozzle assembly back into the plastic shell. Tuck the recoil spring in the shell. Reassemble the shell and reinstall the screws.
  • Insert the bolt and nozzle assembly back into the plastic shell.
  • Tuck the recoil spring in the shell.
  • Reassemble the shell and reinstall the screws.
Agregar Comentario
Place the auto sear spring back in place as shown in the first picture. Insert the pin and brass spacer halfway in, then place the auto sear in as shown in the second picture. Push the pin all the way in. The spring leg that sticks out should point towards the FRONT of the gun. Put the trigger back in place, with the front of the striker resting on top of the brass spacer. Be sure to install the trigger spring properly. Place the hammer over the striker and install the pin through hammer and striker.
  • Place the auto sear spring back in place as shown in the first picture.
  • Insert the pin and brass spacer halfway in, then place the auto sear in as shown in the second picture. Push the pin all the way in. The spring leg that sticks out should point towards the FRONT of the gun.
  • Put the trigger back in place, with the front of the striker resting on top of the brass spacer. Be sure to install the trigger spring properly. Place the hammer over the striker and install the pin through hammer and striker.
Agregar Comentario
Insert the disconnector spring in round slot on the trigger. Put the disconnector back in the trigger and insert the brass trigger pin through the trigger and the disconnector. Insert the disconnector spring in round slot on the trigger. Put the disconnector back in the trigger and insert the brass trigger pin through the trigger and the disconnector. Insert the disconnector spring in round slot on the trigger. Put the disconnector back in the trigger and insert the brass trigger pin through the trigger and the disconnector.
  • Insert the disconnector spring in round slot on the trigger. Put the disconnector back in the trigger and insert the brass trigger pin through the trigger and the disconnector.
Agregar Comentario
Insert the selector drum and rotate the leg from the trigger spring downwards so that it locks in the underside of the selector drum. Insert the selector drum and rotate the leg from the trigger spring downwards so that it locks in the underside of the selector drum. Insert the selector drum and rotate the leg from the trigger spring downwards so that it locks in the underside of the selector drum.
  • Insert the selector drum and rotate the leg from the trigger spring downwards so that it locks in the underside of the selector drum.
Agregar Comentario
Turn the selector switch and the selector drum to the semi auto position. Insert the receiver pin from the left side with the textured end on top (refer to picture). Insert the mag catch arm in its slot.
  • Turn the selector switch and the selector drum to the semi auto position.
  • Insert the receiver pin from the left side with the textured end on top (refer to picture).
  • Insert the mag catch arm in its slot.
Agregar Comentario
Slide the mag catch spring over the shaft and reinstall the button. Slide the mag catch spring over the shaft and reinstall the button.
  • Slide the mag catch spring over the shaft and reinstall the button.
Agregar Comentario
Drop the round nut in the buffer tube with the slotted side facing up. Be sure it is still facing this way once it hits the bottom. Reinstall the buffer tube and buffer tube plate on the receiver Insert the screw and tighten it.
  • Drop the round nut in the buffer tube with the slotted side facing up. Be sure it is still facing this way once it hits the bottom.
  • Reinstall the buffer tube and buffer tube plate on the receiver
  • Insert the screw and tighten it.
Agregar Comentario
Reinstall the stock. Reinstall the pistol grip and tighten the screw.
  • Reinstall the stock.
  • Reinstall the pistol grip and tighten the screw.
Agregar Comentario
Slide the hop-up bucking onto the barrel, making sure to line up the protrusion in the bucking with the slot in the barrel. Slide the barrel into the hop-up unit with the hop-up window facing up. Pop the clip back in place.
  • Slide the hop-up bucking onto the barrel, making sure to line up the protrusion in the bucking with the slot in the barrel.
  • Slide the barrel into the hop-up unit with the hop-up window facing up. Pop the clip back in place.
Agregar Comentario
Slide the barrel into the upper receiver.
  • Slide the barrel into the upper receiver.
Agregar Comentario
Insert the bolt assembly into the lower receiver, starting with the rear end first. Pull the bolt back slightly while lowering the front. Reinstall the rear takedown pin. Reinstall the rear takedown pin.
  • Insert the bolt assembly into the lower receiver, starting with the rear end first. Pull the bolt back slightly while lowering the front.
  • Reinstall the rear takedown pin.
Agregar Comentario
Hook the larger end of the charging handle spring on the nub on top of the bolt assembly. Hook the charging handle onto the other end of the spring.
  • Hook the larger end of the charging handle spring on the nub on top of the bolt assembly.
  • Hook the charging handle onto the other end of the spring.
Agregar Comentario
Slide the upper receiver back onto the lower receiver. Push the front takedown pin back in.
  • Slide the upper receiver back onto the lower receiver.
  • Push the front takedown pin back in.
Agregar Comentario
101 Tech USA
Miembro Desde 06/08/12
3,346 Reputación
17 Guías creadas
Really helpful, and informative!
thank you,
Nick Diamond - Contestar
Very nice work !!
sparvar - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 3
Últimos 7 Días: 21
Últimos 30 Días: 99
Todo El Tiempo: 10,672
