Saltar al contenido principal
Este desmontaje no es una guía de reparación. Para reparar tu Christmas tree, utiliza nuestros manuales de servicio .
  1. Christmas Tree Teardown, Christmas Tree Teardown: paso 1, imagen 1 de 1
    • The teardown shows a christmas tree Nano, but should you have a bigger - Classic one, you may follow these steps - upscaling everything.
  2. Christmas Tree Teardown: paso 2, imagen 1 de 2 Christmas Tree Teardown: paso 2, imagen 2 de 2
    • First order of business: presents!
    • Use caution and joy when opening your presents.
  3. Christmas Tree Teardown: paso 3, imagen 1 de 2 Christmas Tree Teardown: paso 3, imagen 2 de 2
    • Disconnect the power plug
    • Remove the power socket, should there be one on your tree.
  4. Christmas Tree Teardown: paso 4, imagen 1 de 1
    • To remove the baubles, lift them gently and untangle the string from the branch.
  5. Christmas Tree Teardown: paso 5, imagen 1 de 3 Christmas Tree Teardown: paso 5, imagen 2 de 3 Christmas Tree Teardown: paso 5, imagen 3 de 3
    • If you find a capacitor on your christmas tree, straighten its leads to detach it.
    • All discrete electronic elements should be removed in this manner.
  6. Christmas Tree Teardown: paso 6, imagen 1 de 1
    • Protective hand-wear may come in handy.
  7. Christmas Tree Teardown: paso 7, imagen 1 de 1
    • Remain gentle, even when an element is very difficult to untangle.
  8. Christmas Tree Teardown: paso 8, imagen 1 de 2 Christmas Tree Teardown: paso 8, imagen 2 de 2
    • To remove the top ornament, lift it upwards.
  9. Christmas Tree Teardown: paso 9, imagen 1 de 1
    • Finally, remove the lights.
    • Begin with the light that was placed as the last. If you are uncertain, start from the topmost one.
  10. Christmas Tree Teardown: paso 10, imagen 1 de 2 Christmas Tree Teardown: paso 10, imagen 2 de 2
    • Before you run around barefoot in celebration, clean up.
    • Check amongst the floor sweepings for any surface mount components components which may have gone missing during assembly, and carefully put them aside
    • The christmas tree is disassembled!
    • Check whether your local council will take your old Christmas tree for recycling. Burning is not recommended on account of the CO2 emissions it would produce.
    • Thank you for reading, hope you are having a happy holiday.
    • Fix yourself a wonderful New Year in 2019!
baq
Miembro Desde 10/14/09
305 Reputación
3 Guías creadas
Un comentario
skuirel sed it good!
Kyle Wiens - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 4
Todo El Tiempo: 8,625
