Introducción
What's in the dictionary? What chips does it use? Can we get any hits to hack the dictionary?
Este desmontaje no es una guía de reparación. Para reparar tu Casio E-A400, utiliza nuestros manuales de servicio .
The CASIO E-A400 dictionary is a French English Chinese dictionary sold in China.
  • The CASIO E-A400 dictionary is a French English Chinese dictionary sold in China.
  • We don't know what the OS it is using. We can't add more add-on dictionary to it. We want to know how to hack it.
Agregar Comentario
This is the method to enter the hidden TEST MENU. Power off dictionary Hold the go-back key (for newer modules it is near the four navigation keys older modules it is on the left), the page up key and the power key for maybe 5 seconds until it beeps and the screen light on and popup a window shows the Model and the BIOS Ver Release the three keys and press the right navigation key two times then press enter key then it will beep two times and enter the hidden TEST MENU If the dictionary is a newer module like E-A400 (released on 2010 in China) or E-B400 (released on 2011 in China) there is a password when you want to enter the MANUAL CHECK > SERVICE MENU. If it is an older module like E-SF300 (released on 2009 in China) there is no password when you want to enter the SERVICE MENU. The SERVICE MENU has tools that can backup the system file to the SD card. But now no one knows what the password is. Does anyone have any ideas about how to hacking the password? If the dictionary is a newer module like E-A400 (released on 2010 in China) or E-B400 (released on 2011 in China) there is a password when you want to enter the MANUAL CHECK > SERVICE MENU. If it is an older module like E-SF300 (released on 2009 in China) there is no password when you want to enter the SERVICE MENU. The SERVICE MENU has tools that can backup the system file to the SD card. But now no one knows what the password is. Does anyone have any ideas about how to hacking the password?
  • This is the method to enter the hidden TEST MENU. Power off dictionary Hold the go-back key (for newer modules it is near the four navigation keys older modules it is on the left), the page up key and the power key for maybe 5 seconds until it beeps and the screen light on and popup a window shows the Model and the BIOS Ver Release the three keys and press the right navigation key two times then press enter key then it will beep two times and enter the hidden TEST MENU
  • If the dictionary is a newer module like E-A400 (released on 2010 in China) or E-B400 (released on 2011 in China) there is a password when you want to enter the MANUAL CHECK > SERVICE MENU. If it is an older module like E-SF300 (released on 2009 in China) there is no password when you want to enter the SERVICE MENU. The SERVICE MENU has tools that can backup the system file to the SD card. But now no one knows what the password is. Does anyone have any ideas about how to hacking the password?
Agregar Comentario
Remove the screws in the back with a Phillips #1 screwdriver. Insert a plastic opening tool to open the keyboard panel
  • Remove the screws in the back with a Phillips #1 screwdriver.
  • Insert a plastic opening tool to open the keyboard panel
  • Remove screws in the PCB and carefully remove the PCB from the back panel
Agregar Comentario
This is the back panel This is the back panel
  • This is the back panel
Agregar Comentario
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
This is the keyboard panel with soft keyboard This is the keyboard panel with soft keyboard This is the keyboard panel with soft keyboard
  • This is the keyboard panel with soft keyboard
Agregar Comentario
The mainboard SPANSION S29GL256N 256Mbit ESMT M12L64164A 64Mbit
  • The mainboard
  • SPANSION S29GL256N 256Mbit
  • ESMT M12L64164A 64Mbit
  • SAMSUNG K9GAG08U0D 2GB MLC
  • There is a space for another Flash Chip
Agregar Comentario
The small display panel
  • The small display panel
Agregar Comentario
The keyboard PCB and the mainboard PCB is pretty hard to seperate. The keyboard PCB and the mainboard PCB is pretty hard to seperate.
  • The keyboard PCB and the mainboard PCB is pretty hard to seperate.
Agregar Comentario
Insert a plastic opening tool to open the display panel
  • Insert a plastic opening tool to open the display panel
Agregar Comentario
Use a + 2.0 mm screwdriver to remove the two back display panel. Use a + 2.0 mm screwdriver to remove the two back display panel.
  • Use a + 2.0 mm screwdriver to remove the two back display panel.
Agregar Comentario
The PCB of the screen. The PCB of the screen.
  • The PCB of the screen.
Agregar Comentario
Kij
Miembro Desde 31/07/11
170 Reputación
1 Guía escrita
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 3
Últimos 30 Días: 12
Todo El Tiempo: 6,319
