Herramientas Destacadas en este Teardown
Introducción
A simple look into the Universal Dock
Need a flat nose screw driver 2.4mm
philip screw driver #1
Este desmontaje no es una guía de reparación. Para reparar tu Apple Universal Dock Model A1256, utiliza nuestros manuales de servicio .
Pry along the edge of the bottom of the case. It will just pop out.
  • Pry along the edge of the bottom of the case. It will just pop out.
Agregar Comentario
Remove the top case from the bottom.
  • Remove the top case from the bottom.
Agregar Comentario
There are five Phillips screws holding the metal brace down (In the picture I have already removed them).
  • There are five Phillips screws holding the metal brace down (In the picture I have already removed them).
Agregar Comentario
The brace is glued in near the ir-sensor. You may have to apply a little bit force to remove it, but it will come out with just pulling. (You can pry it a little bit with a spudger or a screwdriver) The brace is glued in near the ir-sensor. You may have to apply a little bit force to remove it, but it will come out with just pulling. (You can pry it a little bit with a spudger or a screwdriver)
  • The brace is glued in near the ir-sensor. You may have to apply a little bit force to remove it, but it will come out with just pulling. (You can pry it a little bit with a spudger or a screwdriver)
Agregar Comentario
The only major chip located on the circuit board. (All those who have wondered about the dock's line out, I think we are clear now.) The only major chip located on the circuit board. (All those who have wondered about the dock's line out, I think we are clear now.)
  • The only major chip located on the circuit board. (All those who have wondered about the dock's line out, I think we are clear now.)
Agregar Comentario
Devilac
Miembro Desde 23/06/10
67 Reputación
1 Guía escrita
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 2
Últimos 30 Días: 20
Todo El Tiempo: 22,006
