Herramientas Destacadas en este Teardown
Introducción
Here you will see a breakdown of the Apple Studio Display M2454. This will be useful in repairing broken or malfunctioning parts in the future.
Este desmontaje no es una guía de reparación. Para reparar tu Apple Studio Display M2454, utiliza nuestros manuales de servicio .
Notice that the main components of the monitor are only accessible from the back of the device.
  • Notice that the main components of the monitor are only accessible from the back of the device.
Agregar Comentario
Locate the four hex head screws located on the corners of the back panel.
  • Locate the four hex head screws located on the corners of the back panel.
    • Remove the screws with a 2mm hex screwdriver.
Agregar Comentario
Remove the clear and gray back panels.
  • Remove the clear and gray back panels.
Agregar Comentario
Remove the three screws with #2 phillips head screwdriver.
  • Remove the three screws with #2 phillips head screwdriver.
Agregar Comentario
To remove the metal panel, push towards the bottom of the monitor to release its clips and pull the panel away.
  • To remove the metal panel, push towards the bottom of the monitor to release its clips and pull the panel away.
Agregar Comentario
Remove screw holding the plastic bracket with #2 Phillips head screwdriver.
  • Remove screw holding the plastic bracket with #2 Phillips head screwdriver.
Agregar Comentario
Remove the four screws on the metal bracket.
  • Remove the four screws on the metal bracket.
Agregar Comentario
Remove the two philips head hold-down screws with the #2 Phillips head screwdriver.
  • Remove the two philips head hold-down screws with the #2 Phillips head screwdriver.
Agregar Comentario
Remove black connector by pushing the end of the tab closest to the wiring and pulling away from board.
  • Remove black connector by pushing the end of the tab closest to the wiring and pulling away from board.
Agregar Comentario
Remove white connector by lifting tab and pulling away from board.
  • Remove white connector by lifting tab and pulling away from board.
    • Be careful when lifting tabs, they break easily.
Agregar Comentario
Remove connector connected to the hold down previously removed simply by pulling with hand.
  • Remove connector connected to the hold down previously removed simply by pulling with hand.
Agregar Comentario
Now that the main computer cable is detached, remove it away from monitor.
  • Now that the main computer cable is detached, remove it away from monitor.
Agregar Comentario
Remove the two screws holding the USB port in place with #2 Phillip's head screwdriver.
  • Remove the two screws holding the USB port in place with #2 Phillip's head screwdriver.
Agregar Comentario
Remove the screw on the wire hold down with #2 Phillips head screwdriver.
  • Remove the screw on the wire hold down with #2 Phillips head screwdriver.
Agregar Comentario
Remove white connector connected to LCD main board by lifting tab with tool and pulling away from board.
  • Remove white connector connected to LCD main board by lifting tab with tool and pulling away from board.
Agregar Comentario
The USB port is now detached, remove it from monitor.
  • The USB port is now detached, remove it from monitor.
Agregar Comentario
Remove connector on the left bottom corner of the LCD main board by simply pulling with hand.
  • Remove connector on the left bottom corner of the LCD main board by simply pulling with hand.
Agregar Comentario
Remove the connector on the bottom right corner by 1st removing tape first and pulling with hand.
  • Remove the connector on the bottom right corner by 1st removing tape first and pulling with hand.
Agregar Comentario
Remove top right connector of the LCD main board by pulling with hand.
  • Remove top right connector of the LCD main board by pulling with hand.
Agregar Comentario
Remove the final connector of the LCD main board by pulling with hand.
  • Remove the final connector of the LCD main board by pulling with hand.
Agregar Comentario
Remove the four screws on each corner of the main board with #2 Phillips head screwdriver.
  • Remove the four screws on each corner of the main board with #2 Phillips head screwdriver.
Agregar Comentario
The board is now detached, remove it from monitor.
  • The board is now detached, remove it from monitor.
Agregar Comentario
Locate the top and bottom connector on the CCFL inverter and remove it by inserting pin into the small holes and pulling away.
  • Locate the top and bottom connector on the CCFL inverter and remove it by inserting pin into the small holes and pulling away.
    • This step may be easier with two people.
Agregar Comentario
Remove the two screws on the top and bottom of the CCFL inverter with #2 Phillips head screwdriver.
  • Remove the two screws on the top and bottom of the CCFL inverter with #2 Phillips head screwdriver.
Agregar Comentario
The CCFL inverter is now detached, remove it from monitor.
  • The CCFL inverter is now detached, remove it from monitor.
Agregar Comentario
You have now successfully taken apart a Apple Studio Display M2454.
  • You have now successfully taken apart a Apple Studio Display M2454.
Agregar Comentario
Dylan Perry
Miembro Desde 20/01/10
129 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 13-27, Maness Winter 2010 Miembro de Cal Poly, Team 13-27, Maness Winter 2010
CPSU-MANESS-W10S13G27
4 Miembros
5 Guías creadas
This model is also known as the Apple Studio Display 15" LCD.
analogcd - Contestar
excellent wee guide......i came here in my search for a replacement stand for this model.
bobby nailen - Contestar
Failing caps were the main problem with this — no air flow.
Mal - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 2
Últimos 30 Días: 24
Todo El Tiempo: 5,954
