Herramientas Destacadas en este Teardown
Introducción
I teardown a common DTV converter to see whats in it and debunk the "camera" nonsense. This little box has 16MB of RAM and an unknown speed CPU. Well, lets find out!
Este desmontaje no es una guía de reparación. Para reparar tu Access HD Digital Converter, utiliza nuestros manuales de servicio .
Ah, the tiny little box. Reminds me in size of the new Apple TV. Yay for cheapo silver paint. What do you expect for 20 dollars? To open it, you must remove 3 screws. 1 on the back, and 2 on the bottom behind rubber stickies.
  • Ah, the tiny little box. Reminds me in size of the new Apple TV. Yay for cheapo silver paint. What do you expect for 20 dollars?
  • To open it, you must remove 3 screws. 1 on the back, and 2 on the bottom behind rubber stickies.
  • There is also 1 clip you must undo on the back, it's visible.
  • The device takes OTA digital signals and converts it into analogue 480p. Ironic that it's called Access "HD". Composite or coaxial are your choices here.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Once the cover comes off, you must disconnect the front button cable. The front button board does not have much on it. Buttons, 2 color LED and an IR receiver.
  • Once the cover comes off, you must disconnect the front button cable.
  • The front button board does not have much on it. Buttons, 2 color LED and an IR receiver.
Agregar Comentario
The Motherboard only takes up 2/3 of the case. The rest is empty plastic! Unknown CPU with a clock of 100mhz and 16mb of on board RAM. Contains a composite video encoder and some kind of simple video controller capable of 480p resolution.
  • The Motherboard only takes up 2/3 of the case. The rest is empty plastic!
  • Unknown CPU with a clock of 100mhz and 16mb of on board RAM. Contains a composite video encoder and some kind of simple video controller capable of 480p resolution.
  • 4mb Flash DRAM which contains an unknown simple menu driven OS. No advanced features whatsoever.
  • Composite video output, Power in jack
  • RF Transceivers
  • Not much to this little device. It works well at picking up free over the air television. It tends to run hot, so the CPU must not be well designed for such a simple task as decoding MPEG4 streams.
Agregar Comentario
Zenitar
Miembro Desde 07/02/10
149 Reputación
2 Guías creadas
Taking the top off a product is not a teardown. :(
Ryan Guerra - Contestar
I have 2 decoders that have failed,,this is one of them. Seems to have power but doesn't decode. Need to know how to test parts and replace.
Peter Cieply - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 1
Todo El Tiempo: 6,215
