Mi Problema
The old fan had worn out bearings which caused lots of noise and bad performance.
Mi SoluciĆ³n
The switch went well. Took about 30 minutes because the screws were stripped. The comments were very helpful.
Mi Consejo
If the screws are stripped, take a similar size flat screwdriver and put at 45 degrees into the screw so the screwdrivers corner points into he screw, and give a slight tap from each four directions. Then take your Philips screwdriver and try to unscrew. This made it very easy for me.
0 comentarios
